Wanting a Black Bakelite Tele pickguard 8 hole 1 ply made in USA....but can't find any??
daza152
NZ
Hey guys looking for the above mentioned in title can anyone help me please? thanks. I have a new MIM tele coming soon as its the latest one out in Polar white with maple neck, can't wait.....
Darren.
archetype
Fiend of Leo's
Western NY
Callaham, Stew Mac, and Allparts make black, Bakelite 5-hole pickguards. Since Fender never used an 8-hole Bakelite guard, AFAIK, you'll have to drill the 5-hole guard that you buy. I don't know if the Allparts guard is US-made.
Edit: Strange but true, Fender used an 8-hole Bakelite pickguard on some American Standard Teles.
KelvinS1965
Wokingham England
I noticed that the 'guard above has two little holes for the pickup, so if you don't want those holes then you'll have to either just use a 5 hole or use your existing 'guard as a template to drill and countersink the 3 extra holes. Personally 5 holes looks better to me anyway, but depends on your preference.
daza152
NZ
Thanks exactly what I'm looking for but out of stock, I'm not wanting to drill holes, I'd probbly break it...glad to see there is an 8 hole 1 ply black bakelite guard, maybe I'll try ebay. Thanks.
KelvinS1965
Wokingham England
I understand not wanting to drill holes, I guess I assume that everyone is OK doing stuff like that just because I am.
Did you notice my comment about the two small pickup mounting screws though as I don't know if the MIM Tele will need these, so you'll end up with extra holes where you might not want them?
ponycar
Shenandoah Valley, Virginia
Since bakelite guards were 5 hole do what Keith said get 5 hole it should line up. Put it on without tightening all the way. For this test fit do not put a screw in the lower bout horn. Check to see that that hole is not misaligned so that the screw would put pressure on the guard causing it to warp. Enlarge any holes slightly to avoid binding. Cut out for neck may also need slight sanding not to bind. Five hole bakelite Is thin and prone to warping.
daza152
NZ
i would just use the 5 screws that are there. 8 screws on a 1 ply black guard just looks weird and wrong to me.
Well.i went with 8 hole matte black 1 ply....
Beebe
Atlanta
The AllParts guards I've used all had Made in USA stickers on the back. They don't advertise it though, so it might not be guaranteed.
Ronkirn
Vendor Member
Jacksonville, FL
DIY. . .
ron
PJ55
Philadelphia, PA
Warmoth is your best bet to order a 1-ply black 8-hole guard. But, I don’t think they’ll do Bakelite. I’ve used the five hole guard on 8-hole bodies and the Bakelite is so stiff, it won’t warp. And, you get the vintage vibe.
