want to use the Hammond 290CAX rather than 40-18027
Discussion in 'Shock Brother's DIY Amps' started by ouaouaron, Oct 11, 2019.
  1. ouaouaron
    ouaouaron TDPRI Member
    Saint Louis
    starting my planning for the champ micro and found that with shipping the Hammond is about $30 cheaper and Rob says it works well.
    I know how to use the wires in the ClassicTone (red, red, red/yellow, green, green, green/yellow and black, black).
    Does anyone know how to use the correct wires in the Hammond?
    Need to know which are the HT, HT center tap, 6.3v and 6.3v center tap, and which is for the power and power cord (likely black).
  2. rghill
    rghill Tele-Afflicted Silver Supporter
    Glendale, AZ
    King Fan likes this.
  3. Paul-T
    Paul-T Tele-Meister
    London
    I might be wiring mine into my Champ this weekend. Only difference is I'll be wiring my primary in series where you will be doing it in parallel. I see from a previous post you would wire orange and white together, as neutral, with brown and black as hot/live.
  4. rghill
    Glendale, AZ
    According to the diagram, there is no physical CT for 6.3V leads, so you will need a virtual center tap.
  5. ouaouaron
    Saint Louis
    thanks for the help, I am leaning toward the ClassicTone now. I can read and understand some of the Hammond diagram but with my level of knowledge the ClassicTone is easier.
  6. zook
    zook Friend of Leo's
    Cochise, AZ
    I have used this transformer and really think it is the best choice for Champs and Princetons. Use the 315 Volt taps and cut the 275 volt taps short. Put some heat shrink over the ends leaving about 3/8" to fold back onto itself.
    Be sure to wire it for the appropriate primary voltage
  7. Wally
    What is your target B+?
  8. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Wally...Rob shows the B+ at 400vdc (275-0-275) at the first node for the Micro Champ.
    I recently built the Micro JCM800 circuit from his website and it is a rockin little amp! Finally able to crank a tube amp in the house and not upset the wifey. Good luck with your build!
    Wally and King Fan like this.
  9. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    Yeah, this is a Micro -- the advice above to use the 315 taps doesn't line up with Rob's design.
    dan40 likes this.
  10. Wally
    Well, I haven’t studied that Micro; but something told me that one might want to look at the 275-0-275 winding. I decided to ask instead of opining as normal for me...some look for something with higher voltages. House amp...single 6V6...
    dan40 likes this.
  11. King Fan
    Salt Lake City
    Heh, Wally, good one. In this case, micro means single 12AU7 or 12BH7 power tube. Rob suggests 275 HT for this (he uses SS rectification), but also says:
    "Really any 190-0-190V (285V B+1) to 300-0-300V (430V B+1) transformer will work. If you plan to use a tube rectifier like the EZ81 (9 pin) or 5Y3 (8 pin) then I recommend the CT 40-18028 300-0-300v.... The higher voltage is needed due to the 30+ volt drop of a tube rectifier."​
    Wally likes this.
