Vox Pathfinder Owners
Discussion in 'Amp Owners Clubs' started by robb3566, Jun 12, 2009.
  1. robwid91
    robwid91 TDPRI Member
    Tasmania
    Hi richey88, how do you like the ac10 compared to the pathfinder?
  2. drob
    drob Tele-Holic
    Toronto
    I'll chime in. The 10 is a great little amp. My first Vox tube amp. What struck me when I got it was the similarity in sound of the Pathfinder.
  3. richey88
    richey88 Friend of Leo's
    philly suburbs
    I love it. Run both in stereo (faux) out of my delay, covers bar gigs and miked for larger shows. Really surprised and the low end it puts out!
  4. teleman1
    teleman1 Friend of Leo's
    Arizona
    I have the Pathfinder without reverb and there is no reason to miss it. Mine has the blue 8 inch. It sounds fantastic. All the Vox chime i want.
  5. StormJH1
    StormJH1 Tele-Holic
    Twin Cities, Minnesota
    I have both also. I guess I haven't thought much about whether they sound similar to each other - there's a pretty big difference in both volume and depth with the AC10C1 being a 10" tube combo that's really kinda punching above its weight class in term of the low end it puts out.
    Even though I use both exclusively at home, the Pathfinder isn't an amp I grab if I just want to be loud. Depending on the guitar used, I probably have the volume set between 11:00 and 12:00, and I have the gain set between 9:00 to 10:00. Yes, both the Pathfinder 15 and AC10C1 do an admirable job projecting that Vox "chime" I love so much, so in that way they are similar.
    But another way they are different is that I consider the Pathfinder 15 to be pretty good as a neutral "pedal platform", whereas the AC10C1 really isn't. The AC10C1 sounds terrific, but it's a top boost circuit, so it's pretty much just varying degrees of "dirty" all over the dial. Some forms of gain will take well to that sound, but others will not (particularly hard clipping).
    That's probably one area where the Pathfinder benefits from being solid state amp - if you just a want a nice clean "reference" tone to layer a pedal on top of, the Pathfinder can do that pretty well. And it can also simulate the sound of a breaking up tube amp, even though it's doing it with transistors and other solid state components.
    havlma1, amorica and BIGD5 like this.
  6. richey88
    philly suburbs
    ^^^definately
  7. richey88
    philly suburbs
    The line out sounds pretty good straight into the PA too, did that at "keep your volume down" gig. We were all very pleased.
  8. LGOberean
    LGOberean Doctor of Teleocity
    Corpus Christi, Texas
    I haven't done that in a while, but when I needed to play to a larger room than my Pathfinders alone can handle, I'd line out to the PA, and point my PF15R towards me. This configuration worked like a charm. If the need arises, I'll do that again in a heartbeat.
    richey88 likes this.
  9. Michael A.
    Michael A. Tele-Afflicted
    Virginia Beach, VA
    I recently found a $10 Pathfinder (pre-15R) on CL, the cheap price due to the input jack being loose on the circuit board and the grille cloth was gonzo. So I pulled out the chassis and made it into an extension cab. I had a WGS Veteran 10 that I was not using, so that went in. I made a new baffle from plywood and added a jack. The most expensive part of the job was buying more cloth, but was able to get enough for $27 shipped to cover the full face of the new cab and have enough left to recover the face of my Cambridge 15, which is my driver amp. I have not had time to do that project yet. I prefer the brown replacement cloth, it is more vintage looking. I think it came out pretty well.
    IMG_20160812_122605227_HDR.jpg IMG_20160828_184420297.jpg IMG_20160902_104253460.jpg
  10. rdo1708
    rdo1708 Tele-Holic
    Milwaukee
    I have a PF15 that stopped working on me. Can't figure out what's wrong with it. And I don't really have the time or expertise to fix it. How much would it be worth if I decided to sell it as is? $40?
  11. rdo1708
    rdo1708 Tele-Holic
    Milwaukee
    I figure, you can't even find an open back extension cab for less than $75-$100 so for $40 it would be a steal. But am I dreaming?
  12. StormJH1
    StormJH1 Tele-Holic
    Tough to say, but there's enough of a demand for them and a bunch of modding projects, so maybe $40 would be worth a try so long as you made very clear that it stopped working and is being sold "as is".
  13. lareplus
    lareplus Tele-Afflicted
    tucson, az
    I wish Vox would re-issue the 15R as a 50W or 75W amp with a 10" or 12" speaker. I bet they would sell well. Peavey sells plenty of Bandits. Vox could do that. It would be great as a clean jazz amp. .
  14. BorderRadio
    BorderRadio Doctor of Teleocity Silver Supporter
    Phoenix, AZ
    I wish Vox would revive the 15SMR. I saw a used one up here in PHX for waaayy too much, still wish I nabbed it.
    Honest Charley and robb3566 like this.
  15. robb3566
    robb3566 Tele-Afflicted
    Down the shore
    I wish they still made the T-60 bass amp. I feel like 60 watts is maybe too big for an apartment amp and way too small to play out, so maybe they didn't sell, but they were just so good looking!
  16. Unadan
    Unadan Tele-Holic
    Portland, Oregon Metro
    I just picked up a second 15R. This one is made in Korea. My other 15R is made in Vietnam. The only difference between the two (other than the color of the grill cloth) is that the Korea model is quieter on lower settings and has a more pronounced volume sweep that the Viet version. Both get identically loud - the Vietnam version just gets louder faster - maybe a slight difference in speaker construction?
  17. BorderRadio
    Phoenix, AZ
    Maybe wide variation in taper specs--or even a swap for log vs linear...
    Unadan likes this.
  18. amorica
    amorica TDPRI Member
    Colorado
    Hey guys, Im a huge Pathfinder fan! Just sold the rest of my Fenders Deluxe , Princeton , etc.. Tired of the weight and honestly PF's are my absolute go too. They just fit tone, volume, reverb, trem physicality all of it. Especially being a songwriter. I've never had an amp be so inspiring while singing and playing.
    I have a chance to grab a Cambridge 30 reverb for a $175 ...
    Will it give me Pathfinder tones but with more volume? Thats really all I want. Could really care less about the tube channel. The Cambridge has already been thru and repaired from Cambridgitis . Btw, I already have a stereo 4x10 cab with Eminence Legends 1058 I can use for the my Stereo PFs... Also just snagged this PF off of Reverb in a Oak 2x10 cab... Tried doing a search but not really a direct question comparing the 2 amps. and geez 147 pages
  19. 4telecaster4
    4telecaster4 Tele-Meister
    So how does it sound? I've been wanting to do something like that . There is someone on YouTube who made a 1-12 cab for his.. a traditional vox style with red tolex. I have 11 amps 3 tweed and 5 blackface plus two oddball amps and a15r.....it's one of my favorites!! I've used these out with a 12 inch cab....to have a all in one....just one thing to carry would be perfect. So how does this sound?
  20. amorica
    Colorado
    Actually haven't got it yet. Seller just shipped it out today . Real nice guy. Pathfinder fan as well. I'll definitely post a review .
