ddttyyrr027
Hello folks,
I'm new to the forum and this is my very first post, I'm a tech but obviously not good enough to understand what's going in my Vox Night Train 15H amp now. And I want to learn something new.
I replaced the output transformer with a different primary impedance than the original one. The VOX's schematics mentions 5200 Ohm impedance on the primary. The new transformer I got isn't the drop in replacement and its primary impedance is 6k or 8k Ohm, depending on the wiring. I used 6k.
Now, after the replacement there's is an annoying oscillation starting around 12kHz and ends somewhere around 20kHz.
The oscillation pitch and volume depends on GAIN, whole tone stack and VOLUME knobs. If the GAIN is at 0, no oscillation. If the guitar isn't connected, no oscillation either. Oscillation pitch and volume can be changed with the volume knob on the guitar.
This all points to V1. The whole system is kinda unstable and when both VOLUME and GAIN are at max, the amp goes to some kind of saturation and it starts motorboating with a lot of noise in the background.
Do you have any idea what should I start with. Things I already tried were swapping leads on the OT, added 100pF in parallel to V1's plate resistor, added 1nF cap in parallel with C19 in the grid circuit of V1, still no change.
Any ideas or tips are very much appreciated.
Thank you
D.
Thank you
D.
