Vox-ish build - B+ issue
mallard
Southern US
Quick backstory - I'm building AC15ish, based mostly on Mojotone's 3015 with a few minor tweaks to taste. I'm using their chassis but I already had the 18w transformer set from Hammond in stock so I'm using that (and a choke also to be installed).
I've begun wiring in the power supply, starting with the PT (290-0-290) and recto (no filter caps etc yet).
I fired up the PT, checked the HT secondaries (312VAC from each to CT, unloaded).
Installed EZ81 and probed the rectified B+ coming out at 281VDC. The schematic would have me at about 372VDC loaded, so I would expect something a bit higher here.
Thinking maybe something was up with the EZ81, I rigged up a full wave recto with 2 4007s and a 250R sag resistor, and measured out the exact same raw B+ at 281VDC.
So it's been a while since ive done a build - is what im reading correct, or did i miss something somewhere?
mallard
Southern US
So Ive got the amp built out, checked voltages unloaded and with the preamp tubes only - looks fairly close (a little high unloaded as expected). The final filter cap is reading a hair low but that can be adjusted via the dropping resistor later.
When I install the power tubes, my voltages are dropping about half across the board. Not sure why - any thoughts? I've tried 2 sets of power tubes but I cant vouch for their condition as i havent tested them yet in a working amp.
No signal getting thru....but if i probe the OT primary wires i get the scratchy sound out of the speaker....so maybe im close...
Scooby9261
connecticut
Wish i could help, but i am very interested to see what the solution ends up being. One of my next builds i want to do a AC15 type build. How did you like their kit ? When i first build an amp i like to get a kit and then the next time ill stray a little and do my own thing with it. But curious what some of you might recommend for an AC15 ish kit out there.
Good luck on figuring out the issue ;-)
D'tar
WNY
How bout some photos? Wheres your HT CT? Power and filter pics may help. Or just a full photo dump cause we like amps!😜
mallard
Southern US
OK i'll work on some photos. Can I attach them here or need to upload to a 3rd party site and link?
@Scooby9261 I didnt buy the kit, just their chassis. I had most of the parts in stock already.
Mods:
I did my own layout on turret board loosely based on theirs.
Ran a small filter cap and voltage divider to supply a panel LED (instead of 6.3v pilot)
Preamp filters are a 16+16 cap can instead of separate electrolytics
Single input jack feeds a dpdt switch to change channels, instead of a mess of input jacks (also grounds the not in use channel)
Kevin Wolfe
Lakeland FL
You can snap pics with your phone. Then at the bottom of you post you’ll see a box marked attach files. Click on that and it’ll give an option to link your “photo library”.
mallard
Southern US
Less dress ain’t my bag - don’t judge harshly…
D'tar
WNY
This looks dangerous😳... How do you connect the uninsulated clips to the circuit?
Is 100v sufficient here?
Not that I see anything wrong but I would like to see a clear view of the EZ81 rectifier socket wiring and if you could identify pin 1, and explain the pin connections that would be great!
mallard
Southern US
1) that is cap bleeder resistors for safety. Connected before startup so the caps drain quickly.
2) the 100v cap feeds the panel LED from a voltage divider. It’s connected directly to the raw rectified DC. Perhaps this circuit is putting a load on, but voltages look fine until power tubes go in.
3) it’s a standard ez81 arrangement, except I have backup diodes jumping from 2 unused pins to the active pins. If that doesn’t make sense I’ll get a better pic or sketch it.
Like this but Noval not octal:
BigDaddy23
Are you missing a wire from pin 8 on V1? Looks like u have a spare turret in the vicinity there for the bias resistor and cap to be installed.
Also looks like a shield may be close to shorting on that signal switch??
