vox choke questions for an ac10
Discussion in 'Shock Brother's DIY Amps' started by Dennis Perusse, Oct 22, 2019.
  1. Dennis Perusse
    Dennis Perusse Tele-Meister
    Amesbury Mass
    Hello everyone,
    I have a question on early vox chokes. Once I finish up one of my other projects I plan on starting to acquire parts to do a vox ac10 build and put it in an ac30 chassis as I have one. I plan on using one of the original schematics for this build and I plan on using an L-shaped chassis using the original tube configuration, but I'm stuck slightly on what choke to look for.
    Now on the two schematics that I have, both from Vox, one says to use a 5h 120 ma choke. No another schematic shows to use an 8 hy 120 ma choke. Now I am not sure which one to use as I also have "A Service Engineer's Guide to the Vox AC30 Valve Amplifier" and it also shows an 8 hy 120 ma choke.
    Now here is the rub, I am having a bear of a time trying to find an 8hy choke but I can find a 5 hy choke easily. Does it matter if I use the Classic tone choke ( http://www.classictone.net/40-18032.html ) from the Marshall into the Vox? Personally I don't have a problem with it as it would fit one of the schematics but it bothers me a bit as I wonder should I just use the classic tone for the ac15 (http://www.classictone.net/40-18082.html ) as the circuit is the same for the power and output sections of it?
    Any help settling the confusion is greatly appreciated. :)
  2. corliss1
    Lansing, MI
    I would just use the Marshall. Close counts.
  3. gusfinley
    gusfinley Tele-Afflicted
    SLC, UT
    Another consideration is the DC resistance. I'm not sure what the DC resistance is for an AC10 though. Mercury magnetics makes an exact replacement.
