Vox AC4C1 schematic and mod ideas
Discussion in 'Amp Tech Center' started by PurpleStrat, Feb 2, 2014.
  1. sliberty
    sliberty Tele-Afflicted
    East Brunswick, NJ
    So you are hitting the post tone stack stage harder, probably overdriving it a bit. And I am assuming that the parallel cap is throwing some highs and upper mids away (to ground), is that right? More gain, more middle and lower mids - yea, a touch Marshally indeed.
  2. slagg
    slagg TDPRI Member
    wisconson
    Yes,you are correct.
  3. exabrial
    exabrial NEW MEMBER!
    kansas
    Hey, what are the voltages B+2 and B+3 supposed to be? Thank you! You may have the only diagram of this amp on the entire internet.
  4. slagg
    slagg TDPRI Member
    wisconson
    here is my latest updated schemo.She does the classic Rock Thing in spades now.I have not read the volts on these points but the next time I open it up I'll post them.
  5. Kingsangels
    Kingsangels TDPRI Member
    US
  6. Kingsangels
    US
    Hello, Did the C6/C20 on 2016
    Vox ac4c1 1-12. Just clipped one leg on each. Turned on and no sound. Any help would be much appreciated. Was thinking maybe since its 1 channel amp. Maybe should of kept c/6?
  7. sliberty
    East Brunswick, NJ
    The bright caps simply connect across the gain and volume pots. if they are not present, the amp should still make sounds, just not as bright. If you clipped the correct capacitors, and assuming that the loose leg is not touching anything that it shouldn't, the amp should still work.
    Photos might help us give you more ideas.
  8. Kingsangels
    US
    Awesome Thanks for quick response.
    Will check out if there touching. Maybe i will just clip them all the way out.
    Pretty certain I clipped the right ones. Definitely send a pic. Thank you so much. Pretty bummed out.
  9. slagg
    slagg TDPRI Member
    wisconson
    you clipped c5 coupling cap I'm sure.Resolder that cap and clip c6
  10. Kingsangels
    US
  11. Kingsangels
    US
    Thanks again. Here is a pic.
    Looks like I clipped the right capacitors. How long for volts to dissipate
    light turns in no sound. I did notice when I plugged amp back in switch was on. Could i have blown fuse. Or something whith speaker. Im lost this is frustrating. Lol
  12. slagg
    slagg TDPRI Member
    wisconson
    Yeah looks like you clipped the correct one.It could be that one of the leads you clipped is grounding out under the board.Alse Make sure your OT leads have not come loose.
    Did your speaker leads come unhooked?
  13. Kingsangels
    US
    Speaker leads good.What is Ot leads? If grounding out. Any ideas? Also been unplugged for 3 days. Think im good for not getting Shocked? Thanks for info
  14. sliberty
    East Brunswick, NJ
    Has the amp power switch been in the on or off position while the amp was unplugged?
    If you are hoping to drain the filter capacitors for your personal safety, the amp should be unplugged, and the power switch should be in the ON position. If so, an hour is probably more than enough.
    But having said that, and please do not take any offense, the fact that you asked about getting shocked suggests to me that you probably shouldn't be messing around inside the amp too much on your own. I'd recommend that you bring the amp to a qualified tech.
    However, if you decide to continue diagnosing on your own: there are two fuses on the board. My schematic doesn't show them, so I don't know which is which. But one of them is going to be a mains fuse, and the lamp wouldn't even turn on if that fuse was blown. The other could be a fuse to protect the OT, or some other aspect of the circuit, and if that one was blown, perhaps you'd have a working lamp but no sound. Regardless, check the two fuses by removing them (one at a time) and testing with a multimeter. If they have continuity, they are OK. If not, they need to be replaced. You must replace the fuse with the identical type (physical size, amps and speed - slow or fast blow). If you replace a fuse, and it blows again, something else is wrong, like a bad power tube, or rectifier (diode) or something else.
  15. slagg
    slagg TDPRI Member
    wisconson
    The "OT"output transformer leads,spade type ends plugged into the board coming out of the transformer.Also with needlenose pliers wiggle the cut ends were you clipped the cap c6.If it's loose it may be grounding out on the other side of the board.Be careful and do not man handle it. The board has very thin traces on the other side.
    Tootle likes this.
  16. slagg
    slagg TDPRI Member
    wisconson
    Hmmm,silence ?
  17. Kingsangels
    US
    Lol ! Just opened it now. So i see C6 pin that was cut. Bent and touching board. So i straightened it up. Not sure if this is what ya meant by grounding out. Will button it up and try again. If nothing will resolder. I did see this pushed up part on board by treble pot. Must of came that way. Hopefully this isn't the cause.
  18. Kingsangels
    US
  19. slagg
    slagg TDPRI Member
    wisconson
    Strange
  20. sliberty
    East Brunswick, NJ
    If you are referring to the large wattage pink resistor, I think that it is typical for it to be sitting high, although I don't know why.
    I assume that you pilot light is coming on, right?
    Have you tried different tubes? Try replacing one at a time with known good tubes. In fact before you replace any, take arch tube out of its socket, and then put it back in making sure it seats well. If no change then try replacing one at a time.
