Vox AC15 No sound in external speaker after speaker swap
Discussion in 'Amp Central Station' started by jonyorker, Sep 25, 2019.
  1. jonyorker
    jonyorker Tele-Meister
    ottawa
    Hi Folks,
    Today I received the wgs black and blue speaker to upgrade my AC15.
    Everything went well, and the amp works fine.
    However, when I try to use the external speaker-> attenuator -> speaker I get no sound whatsoever.
    Cables fine, attenuator fine, speaker is fine.
    What gives? How can I fix this?
  2. jonyorker
    ottawa
    Interesting,
    so after more digging, it seems when I have two speaker cables connected to the new WGS speaker, one pair doesn't get a signal.
    I'm lost, as I've done this on my two other amps, and the greenback that used to be in the AC15.
    Why would the WGS speaker give no sound on one pair of spades, if the other is connected?
  3. milocj
    Michigan
    Have you checked to make sure that all of the spade connections are passing signal to the WGS without the extra items hooked up? Possibly a bad wire from one of those to the voicecoil
  4. jonyorker
    ottawa
    I can put the amp in either spots, or the feed from the attenuators in either spot.
    hook both up, no signal on the external no matter which pair of spades I connect it on, and have the amp on the other.
  5. muscmp
    muscmp Tele-Afflicted
    california
    did you contact wgs regarding this?
    play music!
  6. jonyorker
    ottawa
    Not yet, will do so.
    just got the speaker today and wanted to run this issue by you fine folks to see if I’m being stupid or not.
