3-Chord-Genius
Same here, but I started tinkering with the gain and tone knobs - they are *very* interactive on this amp. With the gain around halfway up, and the bass cut way back, what you are describing doesn't happen to me anymore. And don't worry about losing bass when you turn the knob back; you will have as much bass as before, but it will stop doing that rumbling thing you're talking about.Hi all. I´ve been trying to join the club for a while, but it has not been easy. I will try to explain as good as i can with my limited abillity to speak english. I bought an ac 10 in the end of july but it had some problems. It did not respond well to the note E. When I hit an E note, open E string or at the twelfth fret the note resonates in the amp and gets really loud and sustains for a long time, and the amp rattles quite loud as well. It also happens on other places mostly on the low strings and it get worse from the twelfth fret and up. So I sent it back to the store for them to look at. After more than a month I got the amp back, they said that the tube sockets had been tightened. But the amp was just like before I sent it back.
I spoke to the shop and they apologised and said that i should get a different one. I recieved the new amp today and this one have the same problem, only worse, it now happens on several different notes, from the twelfth fret and up it happens almost on every note on the low strings. I´ve tried different guitars and it is the same problem. I really like the amp apart from the resonating problem. But it is unusable like it is now. I think it is strange that this happens on two different amps. And hope someone here can help me solve the problem.
