Volume pot issue
Discussion in 'Tele-Technical' started by JSMac, Apr 21, 2021.
  1. JSMac
    JSMac Tele-Holic
    Front Range Colorado
    Hey folks,
    I'm installing a Hot Rails in an Esquire build. I'm using a push/pull volume pot for coil tapping. The coil tap wiring seems to be correct and probably doesn't have anything to do with this issue.
    The pot seems to be working when I test it with an ohm meter. It ranges from about 23 ohms the 475k. But, when I wire it up It doesn't cut the signal. The pickup is wired to the outer lug and the jack is wired to the center lug. I can't figure out how the signal is getting through with the volume turned down? Any ideas?
  2. ale.istotle
    ale.istotle Tele-Holic Silver Supporter
    Pennsylvania
    Is the other outer lug wired to ground? The pot doesn't really cut the signal. It shunts part of it to ground.
    spellcaster likes this.
  3. JSMac
    JSMac Tele-Holic
    The other outer lug is grounded.
  4. ale.istotle
    Pennsylvania
    Well, It's time for pics I guess.
  5. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    Wait a minute. Isn't it supposed to start at ZERO Ohms?
    Doctorx33 likes this.
  6. Falstaff1960
    Falstaff1960 TDPRI Member
    Arizona
    oh..so not a thread about having too much weed on hand?
    Doctorx33 and TwoBear like this.
  7. JSMac
    JSMac Tele-Holic
    I don't think I've seen one read zero unless it was a no load pot.
  8. JSMac
    JSMac Tele-Holic
    This may not be much help. I’ve been clipping in the connections with jumpers.
    The white wire on the left is the signal from the pickup. I connect the center lug to the output jack. I connect the right outer lug to the ground of the output jack and to the pot housing.
  9. TwoBear
    TwoBear Tele-Holic
    oc. CA.
    Is the push pull the volume? My eyes suck but it doesn’t look like it has anything connected to the middle?
    AAT65 likes this.
  10. JSMac
    JSMac Tele-Holic
    Sorry, I edited my last post to describe how I wire it.
  11. TwoBear
    TwoBear Tele-Holic
    oc. CA.
    When I blow up the picture and I see that push pull pot better the one white wire that I see on the left appears to have a line may be a cold solder joint. Another picture may help maybe one without a reflection or someone else with better eyes will probably chime in pretty quick. But yeah 23 ohms? maybe in circuit with some thing but they pretty much go to zero, or 0.1? with the wiper pulled To outside lug. Or at least they should
  12. JSMac
    JSMac Tele-Holic
    Sorry for the poor picture. The white wire isn’t soldered. I just laid it against the lug to show where I connect it.
  13. TwoBear
    TwoBear Tele-Holic
    oc. CA.
    I only see a white wire coming from your white alligator clip/switch and going to the outside lug of that pot. It looks like your red and white go to the switch part of your push pull pot but I don’t see any more connections to the middle and other outer lug of your pot?
  14. JSMac
    JSMac Tele-Holic
  15. LutherBurger
    NYC
    I know this isn't helpful at this point in your project (Sorry.) but I just measured the resistance of a few CTS pots between lugs 1 and 2 with the wipers turned fully counterclockwise, and they all read zero Ohms. That's with nothing connected to the pots, though.
    TwoBear likes this.
  16. JSMac
    JSMac Tele-Holic
    I may be wrong about that. Now I’m curious so I’ll check some new pots and see what they read.
  17. JSMac
    JSMac Tele-Holic
    Alrighty then. The pot is bad. I noticed that when I tested between the center lug and the outer one that would normally be grounded I didn't get a reading unless I pressed down fairly hard on it with my probe. With just good contact, no reading. So, it wasn't being internally grounded when it was wired up. It is a used pot that came with the used pickup.
    I clipped in another pot and BINGO. I'll need to buy another push/pull pot.
    BTW, I tested 4 new CTS pots and none of them read zero when rolled all the way off. They all read between 3.2 and 4.8 ohms, FWIW.
    AAT65, ale.istotle and LutherBurger like this.
