Volume knob on Baja not working properly
Discussion in 'Tele-Technical' started by a1terrier, May 29, 2020.
  1. a1terrier
    a1terrier TDPRI Member
    West Yorkshire, England.
    Hi All
    I have a Fender Baja Telecaster which I have had from new. Not played it for a while, just got it out and plugged in but found that volume control only works from 8 upwards. It wasn’t like that before.
    Does it need a new volume control?
    Checked for loose connections but there are none.
    thanks
  2. moosie
    Western Connecticut
    What does that mean? What happens below 8? No output? Stays that level all the way down?
  3. a1terrier
    Hi
    Thanks for reply
    it’s probably at about 7 when volume starts, nothing before that.
    done a bit of a search and it seems it’s common with Bajas
  4. moosie
    Western Connecticut
    First, I'd check that the outer pot lug is grounded properly. IIRC, that vol pot has an S1 switch on it. Ignore that.
    Next, if you have good continuity to ground from that lug, I'd spray some DeOxit on the track/wiper, and see if that helps.
    If that doesn't fix it, or even change anything, the next step would be to disconnect the leads from the pot (not the switch part, just the pot) and test with a meter.
    The only reason I could see this being 'common' to Bajas, is because it's an S1, and maybe there's some issue with S1s - though I've never had a problem with them... Beyond that, pots are pots, Fender uses CTS throughout, and they don't differentiate by guitar model.
  5. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
    In the UK DeOxit equivalent is Electrolube contact cleaner. Maplins used to sell a cheaper version but alas they are no longer with us.
    Warning! Do not use standard WD40.
    As moosie said, the Baja volume pot is an S1 switch so hopefully the contact cleaner will fix the problem.
  6. a1terrier
    Hi All
    thanks for suggestions
