volume drop after HB install
Discussion in 'Just Pickups' started by swamper95, Jun 17, 2013.
  1. swamper95
    swamper95 TDPRI Member
    Hello. I have just installed a seymour duncan mini HB in to the neck pos on my classic vibe,Love the new pick up. The problem is it seems i have lost all the low end when toggel is in middle position, and a massive volume drop as if its only reading the bridge pic up. I have wired as per schematic hot to toggel and outer mesh cable to volume pot (ground)
    This is my first pick up replacement just wondering if anyone can shed some light on this lil' prob ..
  2. Derek Kiernan
    Derek Kiernan Friend of Leo's
    Princeton, NJ
    Could be out of phase. Switch the hot and ground from the coil on one of the pickups to see if it help - probably the single, since the humbucker might have the ground attached to the shielded jacket.
  3. swamper95
    Thanks Derek ill give that a go.
  4. adam.gotch
    adam.gotch Tele-Meister
    Santa Barbara
    Yes---they are out of phase with one another. You will need to switch the hot & ground wires on the bridge pickup. Let me know if you need any info on how to do that.
