Virtual centre tap resistors?
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Apr 14, 2021.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    Never done a build with these before. Does it matter where they go in the heater wire chain? I was thinking of referencing them to ground at V1, pins 9 and 4. It's a bit crowded by the pilot light.
  2. Wyatt
    Wyatt Tele-Afflicted
    That would be fine.
    BTW, on a cathode-biased amp, like a 5E3, some of us DC elevate the heaters by mounting the resistors on the power tube socket and grounding them to the tube cathode (pin 8 on a 6V6/6L6/etc.).
    Pretty sure this is on of @robrob's drawings...
    King Fan and Nickfl like this.
  3. Uncle Daddy
    Maldon, England
    Thanks. This is a Princeton Reverb so I could use pins 2 and 7 to a ground lug. I'd plans to use both pin 8s for a feed to some tests sockets, to ground via a 1r.
  4. King Fan
    Salt Lake City
    Your lamp may be more crowded than mine, but this typical PR arrangement doesn’t take much space.
    Ignore the tails on the heater wires — I just like to measure heater volts with mini-grip probes 'far from the madding sockets.'
    robrob likes this.
