Thanks folks, really appreciate your suggestions. I'll give the suggestions @Seasicksailor and @Bowpickins laid out a try, but will keep in mind that the general consensus is to get it into the hands of an expert
It's notable to hear such a loud and clear message to go to a luthier (or at least a university violin expert) from this very DIY oriented community.
Good advice here and I would second the opinion to reach out to a professional. Not that it is impossible to adjust a violin, it's just a universe in its own
Fitting a bridge to the top may not be a challenge, but carving it for weight and better resonance is, as they come oversized - assuming of course there is need for such a job.
Soundpost fit and placement is a task, where joi just may not have the right tools, or experience to do it without struggle. There is a sweetspot for the soundpost position behind the bridge, the ends need to be angled and cut cleanly.. and depending on the instrument, the soundpost may just get loose and fall if you loosen the tension of the strings or remove the bridge.
Also, you .ay not have the reamers for cleaning and pegholes or fitting the peds, if that job needs to be done..
I think those are really some of the reasons, folks recommend a luthier
