eddiewagner
Nice Surprise! It’s light! And put together really well. Nice pots and soldering. Trussrod works. Fretboard needs a lot of Oil. Setup and Soundcheck tomorrow.
Can you let us know if the Bigsby stays in tune and how much pitch variation you get. I love doing the Setzer/Duane Eddy thing with the Bisgby on the wound strings but most Bigsby teles I've played don't lower the pitch like a Gretsch does. I know a lot of this has to do with angles etc. ThanksNice Surprise! It’s light! And put together really well. Nice pots and soldering. Trussrod works. Fretboard needs a lot of Oil. Setup and Soundcheck tomorrow.
View attachment 899937 View attachment 899938 View attachment 899939 View attachment 899941 View attachment 899942 View attachment 899943 View attachment 899945
It works great because the bridge moves with the strings.Can you let us know if the Bigsby stays in tune and how much pitch variation you get. I love doing the Setzer/Duane Eddy thing with the Bisgby on the wound strings but most Bigsby teles I've played don't lower the pitch like a Gretsch does. I know a lot of this has to do with angles etc. Thanks
Thanks. The Bigsby on my Gretsch (with Reverend soft spring) will lower the low E string down to B when I push it all the way down . Most tele Bigsby I've played will only take it down to D due to the flat body. They will give you a little shimmer but not as much pitch variation as the Gretsch. The soft spring is longer so that could account for some of the difference.
Some people just set it up with the handle higher so it can go lower. Longer Bigsby spring usually does it. Or you can just bend the handle. String gauge makes a difference as well. I believe scale length matters, but don't know for sure. My first modification is always a squishy spring.
