Vintage Saddles for Parsons-White?
Discussion in 'B-Bender Forum' started by Boogie, Mar 3, 2020.
  1. Boogie
    Boogie Tele-Meister
    The Late Great Golden State
  2. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    I have a set of Rutters 50s compensated steel saddles on my bender; he'd probably sell a single.
    Boogie likes this.
  3. asatfan
    asatfan Friend of Leo's
    Beautiful Brown County, IN
    One thing I've found on some benders is, if there is not enough of an angle from the saddle to the where the string anchors, it can have that effect on the sound. Both of my benders have fairly steep angles. I have a standard G&L bridge on my Asat Special and a Glendale with brass compensated barrels.
    8trackmind likes this.
  4. gregulator450
    gregulator450 Tele-Holic
    The Dry Side
    Kmaxbrady likes this.
  5. 8trackmind
    8trackmind Tele-Afflicted
    Dark side of the moon
    I have those same saddles but in steel on my Hipshot. The B string sounds the same as the other unwound strings (it didn't with brass) and it no longer eats the saddle.
    They are a tad brighter but I run a smaller than stock tone capasitor value and just roll the tone down a bit.
    Jlwctn likes this.
  6. asatfan
    My mind must be really going away.....the Glendale with brass saddles is on my Asat Classic.
  7. brookdalebill
    Austin, Tx
    I put some AllParts titanium saddles on my avatar guitar.
    I replaced all three.
    I have not experienced B sting “saw through” since.
  8. Boogie
    Boogie Tele-Meister
    I'm not sure how I would get the angle steeper. I pushed the string down to the bottom of the bender hub under tension, as low as it will go. It didn't help. If the issue I'm having is caused by "saw-through" it seems like this could even make the problem worse.
  9. Boogie
    Boogie Tele-Meister
    I've ordered a set of those in steel. The Rutters look nice, but I like that these are the same design as the brass saddles I already have. I like the design of them. I'll report back!
  10. jd_elam
    jd_elam TDPRI Member
    Alabama
    I have used the Fender 70's style saddle on my Parsons/White for years. (Fender part # 0007698000)
    I just use the one saddle for the B and E string and leave the other two brass ones.
  11. Smokin OP
    Smokin OP Tele-Holic
    Leesburg, GA
    I have the Rutters steel saddles on mine.
  12. connuchar
    connuchar Tele-Meister
    phx az
    eye had brass saddles on a 3 saddle bridge when eye installed a hipshot b-bender [like the fender one bur black] and the b string wore a groove it the brass saddle , had to swap in a steel one for the high-e/b string saddle,it's ok now
  13. Boogie
    Boogie Tele-Meister
