Snfoilhat
I figure it's not too soon to treat the 80s and 90s amps in a way similar to the heavily studied, copied, hyped, and reinterpreted 50s and 60s amps, by working out some more or less faithful clones using the common parts and construction techniques most hobbyists use. You can still find an original Super Champ or Prosonic for about the cost in parts of a good copy, which argues against my thesis here. All the same I'm going to take a swing at detuning some of the 1990s-ness of the Prosonic and see what it sounds like built more in an earlier style.
1st, a Prosonic has been on my list for years, and only this week did it finally occur to me that if I just pick the non-reverb (head only) version, it's both more likely to run correctly than the reverb (combo) version and it will fit in Princeton repro chassis. Every similar repro chassis wider than the PR is drilled for 2 channels and I've never wanted to deal with that.
2nd, I found a front panel slide switch I'm hoping will simplify (and 60s-ify) the user interface
and the channel switching function, since I'm not going to build anything that requires a footswitch and want to eliminate the relays.
Looking at my collection of Prosonic gut shots I've been diagramming the interesting use of dual gang pots in the production amps. It looks like only two of them really needed to be dual though all 7 or 8 were.
I ordered a fresh PR chassis, and my hope is that there's just enough space between input 2 and the volume pot to squeeze in this 3PDT slide switch, which AES doesn't carry (I didn't know it existed) and I ordered from Mouser. It's a little wider than the typical bright switch.
Here's a copy of the Prosonic (non-reverb) schematic
And then I've been working on cleaning it up -- removing the relays, LED, footswitch, simplifying the rectifier+and biasing switching scheme, reworking the power supply according to the power transformer I want to use, and some other minor changes.
https://robrobinette.com/Generic_Tube_Amp_Mods.htm#High_Voltage_Tap_Adjustable_Bias
The grayed-out portions need to be reworked based on the new PT and the power tubes chosen. I don't think I'll pick 6L6GC but something smaller.
I don't expect doing a new turret/eyelet layout of an amp designed for PCB is going to be a cakewalk. You can see in gutshots that virtually every signal lead is shielded. But I think the part count looks manageable for the space and some of the lead dress can be copied from the original.
That's it for now
That's it for now
