FXBDM 1832
My Vibro-Champazoo does not vibrate anymore. I had a few problems integrating the tremolo, and then realized I never used it anyways, and decided to disconnect it from the circuit. This means I have this tube socket sitting empty, as well as three or four chassis openings.
So, as one does, I decided to not leave well enough alone and look into adding a gain stage and potentially a James tone stack, to give it more versatility.
I initially looked at implementing some kind of one wire cascade using one half of the available tube, but all the schematics I have seen have you disconnect the normal input, and I would like, if possible, to retain a normal champ channel.
So first, here is a diagram of what I understand are my options. The third line is what I would want to do (with two tone stack locations, I would use only one). The tube is there, so there is little extra cost to using the two halves (and I can maybe use one as a cold clipper or something).
So: questions:
A) is disconnecting the normal input required in a simple one wire mod?
B) what is the best tone stack location? Later in the chain would affect both channels, but it would be closer to a Marshall implementation if I understand correctly. Earlier in the chain would limit it to the gain channel and would give me my unaffected Champ on normal.
What are your opinions on the principle of the project?
So: questions:
