Vibro Champ - Does Vibe all the Way Down = Vibe Off?
Discussion in 'Amp Central Station' started by Alcohen, May 8, 2021.
  1. Alcohen
    Alcohen Tele-Meister
    San Francisco
    I have a '65 Vibro Champ that didn't come with a pedal. I've always just kept the vibro intensity pot all the way to 0 when I wanted it straight. Is that the same as having the circuit off via a switch? Or is the circuit still in play somehow with the pot at 0?
  2. Lowerleftcoast
    california
    It is still in play. You would need the foot switch or a shorting plug to turn it *off*.
    Boreas likes this.
  3. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
  4. Alcohen
    San Francisco
    Boreas likes this.
  5. corliss1
    Lansing, MI
    In most amps, the plug turns it on. In the Vibro Champ, the plug completes the circuit to ground, shutting it off.
    http://fenderguru.com/wp-content/uploads/2015/04/vibrochamp-schematic.jpg
    The Intensity control all the way "off" shorts the signal coming out of the trem section. The footswitch kills the oscillating section, keeping the effect from happening, no matter where the Intensity control is set.
    Fretting out likes this.
  6. scook
    scook Tele-Meister Silver Supporter
    Etlan VA
    Not a direct answer to your question but my SF VC didn’t come with a footswitch. I got a replacement from Mojotone that looks and works perfectly fine. I’d highly recommend just getting a replacement footswitch.
  7. Boreas
    Duh... I guess you are right!!
    Alcohen likes this.
  8. J. Bonkosky
    J. Bonkosky Tele-Holic Silver Supporter
    Seattle Washington
    The tremolo circuit always will have an effect on the preamp if the depth is above zero. Even with the footswitch set to off. Think of it as a crappy tone control.
    Paul G. likes this.
  9. Willie Johnson
    Willie Johnson Tele-Afflicted
    Chicagoland
    Have any of you guys done the tremolo mod with the SPST pot that clicks off the tremolo? What did it do to the amp's overall gain when clicked off? Curious about this for my SF Princeton--I put a shorted RCA jack in the trem switch input as an experiment but doesn't do anything different than turning both pots down.
  10. Alcohen
    San Francisco
    Could you explain this? What effect? And if you turn the Depth control to 0 rather than the Intensity pot (which, of course, is what I've been doing), does that remove the effect from the circuit?
  11. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    If you had an oscilloscope, you would see that regardless of pot positions or switch position, the tremolo is always on. Always.
  12. fiveightandten
    fiveightandten TDPRI Member
    Connecticut
    I have a SPST on a pull pot for the intensity knob on my BF Deluxe. It just grounds the trem circuit in the exact place that the foot switch does. There is no audible difference in the gain on my amp when clicked on vs. off.
    Willie Johnson likes this.
