Vibro Champ Build #2
Discussion in 'Shock Brother's DIY Amps' started by Phrygian77, Aug 31, 2019.
  1. Phrygian77
    Crawfordville, FL
    IMG_20190830_171812.jpg This starts with a 16" tall slightly deeper cabinet with blonde cosmetics. An Eminence 1028k is on the way. OT is a ClassicTone 40-18030, and the PT is a 40-18027. I'm going to try using the 550VAC secondary with a GZ34, and a Tung-Sol 6V6GT to see where that gets me. Plate voltage may end up too high, so I've got a JJ 6V6s I can drop in if needed. The 40-18109 with the 550 secondary, SS rectified, put me at 360 with a Tung-Sol 5881 running at 21 watts idle.
    This will be the first time I'll be be using mostly CC resistors, just for fun, and Sozo caps (except the tremolo). I'm going to sub in a .022 instead of the .047 for the mid cap. Mid resistor will be the stock 15k instead of a 6.8k. I'm not aiming for clean tones this time around.
    JohnnyCrash, JeffBlue, Alter and 4 others like this.
  2. King Fan
    Salt Lake City
    Sounds like a great plan. You made me look... at this:
    Snfoilhat likes this.
  3. Phrygian77
    Crawfordville, FL
    I've been using them in my PR builds. I get around 415-422VDC with a GZ34 using the 630VAC secondary. I used the M6 version in my last Vibro Champ, since I knew it was going to be idling over 20 watts.
  4. Phrygian77
    Crawfordville, FL
    JohnnyCrash likes this.
  5. TequilaCaster
    TequilaCaster Tele-Holic
    Between Time and Space
    Beautiful! My favorite amp! My favorite speaker too! I am sure your final product will be amazing.
  6. Phrygian77
    Crawfordville, FL
    I've never used one before, but it's supposed to be a copy of the old CTS alnico. I have two CTS orginals, and two recones in a Super Reverb. Awesome sounding speakers, so I'm looking forward to trying this out. I may put a pair in my brown Super build if I like it.
    JohnnyCrash and TequilaCaster like this.
  7. Phrygian77
    Crawfordville, FL
    The last Vibro Champ build, I did it with a 6.8k mid resistor, like the majority of blackface amps. With a 5881 output tube, and a bigger speaker, it was a lot like a non-reverb blackface Princeton.
  8. Phrygian77
    Crawfordville, FL
    Paul-T and tubedood like this.
  9. tubedood
    tubedood Tele-Holic
    Orlando
    Phrygian77 I am watching this thread like most of yours... Eagerly! You do great work and share ideas and tips we all benefit from.
    I used to have an old late 60s Vibro-Champ. She was in great condition. I sold it to buy Christmas presents a long time ago when I was a single Dad.
    Phrygian77 likes this.
  10. Phrygian77
    Crawfordville, FL
    I hear you, man. I sold my '70 Princeton Reverb during the recession a little over 10 years ago.
  11. Phrygian77
    Crawfordville, FL
    Also a single dad at the time.
    tubedood likes this.
  12. Phrygian77
    Crawfordville, FL
    I'm fortunate to be in a position to be doing this right now. I've been building over the last several years, and I've been fortunate enough to attract locals. Since John McNeese left for Athens, there's been no one reputable to work on vintage amps in the area.
  13. theprofessor
    Chattanooga, TN
    That is a gorgeous cabinet, and I'm sure the amp will sound fantastic with that 1028k. I can't wait to see the build!
  14. Phrygian77
    Crawfordville, FL
    Drilling and filing 16 gauge galvanneal, my least favorite part of a build using these chassis.
    Since the cabinet is deeper than a standard Vibro Champ cabinet, I drilled rear holes for the internal speaker jack, an extension cab jack, the RCA tremolo jack, and an NFB switch. Extension cabinet jack will be a Switchcraft 13A wired in parallel with the 12A jack. Transfer circuit on the 13A will switch to the 4 ohm secondary when an 8 ohm extension cabinet is plugged in. I did this on my last Princeton Reverb build also.
    Mounting holes for the grounds are also done. One thing about these Vibro Champ chassis, compared to the PR chassis from the same maker, is that the mounting holes for the PT are smaller and slightly off. I filed the mounting holes them to make it fit, but that's a pain. The next time I'm just drilling the holes slightly larger.
    Also the mounting centers for the 9-pin sockets are off. I had the same problem with the last VC build. I still need to file those to fit. Then, I may need to tweak some of the front panel holes. I didn't do it on the last build, but I should have because some things were slightly off. Although, you really had to look closely to notice.
    JohnnyCrash and Nickfl like this.
  15. Phrygian77
    Crawfordville, FL
    Spent a bunch of time today filing away on the holes in the front of the chassis to get the faceplate to line up better. Still have some more to do. I'd like it a little lower, but I can live with it.
    These were taken before I started ...
    JohnnyCrash, daveIT and robtking like this.
  16. avspecialist
    avspecialist Tele-Meister
    Avon,Ct
    Beautiful so far, i’m looking forward to see the progress
  17. Phrygian77
    Crawfordville, FL
    I don't know why the mounting centers are wrong for the 9-pin sockets on these VC chassis, but their PR chassis have the correct spacing. Anyway, this was last of the filing that I had to do on the chassis. Now the real work can begin.
    Test fitting the faceplate and chassis in the cabinet...
  18. Phrygian77
    Crawfordville, FL
    JohnnyCrash and NSB_Chris like this.
  19. Phrygian77
    Crawfordville, FL
  20. BigDaddy23
    BigDaddy23 Tele-Holic
    Nice!
    In pic 2 above - What's that between the V2 and V3 sockets? A test point??
