I finally got to hear the difference when a tank is installed in a situation that doesn't fit it's design. I got in a '72 Pro rEverb...little dirty and blowing fuses. A filter cap was shorted....all e-caps then replaced. The amp is original and cleaned up to near dead mint condition, so I didn't do any modifications to it. I even left the bias circuit as is. The new JJ's sat in there at 49.6% of max plate disspation...so that is good to go this owner.
When I got the chassis back in the cab and heard the reverb, I was disappointed. I pulled the tank and to my amusement there sat what looked to be an OEM tank....but it is the wrong model. It is a 4AB3C1C instead of the 4AB3C1B that should be in this FEnder, The difference is that the last 'C' in that model number indicates a tank that was built for a vertical mounting while the 4AB3C1"B" is built for horizontal mounting installations. The reverb was shallow and weak with a very quick decay. I oriented the tank in a vertical plane and Voila! there was that wet and warm Fender tube reverb that most of us love so much.
I had never before heard the difference even though I knew that tanks were built for specific applications. Now I know that indeed a vertical tank does not function well in a horizontal plane.
