Versitle Tele
Discussion in 'Other T-Types and Partscasters' started by ScottyMo, Nov 17, 2019.
  1. ScottyMo
    ScottyMo TDPRI Member
    Kinston NC
    Hey, I'm starting my first project Tele. I'm wanting to build a Nashville Style Tele. Want a Humbucker that can switch to a single coil without the 60 cycle hum of a single coil.
    Has anyone got any ideas on that?
  2. ScottyMo
    Kinston NC
  3. ScottyMo
    Kinston NC
    The humbucker would be in the bridge position.?
  4. joeford
    joeford Friend of Leo's
    st. louis, illinois
    can't really do it that way. single coils hum... it's their thing.
    you can get noiseless stacked coils... or twin blades in a single coil sized package that'll get you close... but that's about it.
    you can also get a decent noise gate that'll mitigate some of the noise in a traditional coil split setup
    casey2910 and Fretting out like this.
  5. ScottyMo
    Kinston NC
    Can you use stacked coils beside one another?
  6. mkdaws32
    mkdaws32 Tele-Afflicted Silver Supporter
    Moncton, NB Canada
    Hmm - you could wire two stacked pickups side by side, but I’m not sure how “humbucker” like they would sound. I would go with the traditional tele bridge plate and a Dimarzio Chopper T. Wired normally (in series) it’s a great humbucker. Wired in parallel, it’s very single coil-ish sounding but still noiseless. I have one setup to switch series/parallel/split on an Esquire and it is extremely versatile. I almost never use the split position.
  7. Chief101
    Chief101 Tele-Meister
    Not far from Nashville
    Fretting out and mkdaws32 like this.
  8. ScottyMo
    Kinston NC
    Thanks. I think that's what I'm gonna do. I was wanting to have a really versatile guitar. Sort of a Paisley meets Tom Sholtz Guitar.
    mkdaws32 likes this.
  9. ScottyMo
    Kinston NC
    QUOTE="ScottyMo, post: 9434770, member: 149066"]Hey, I'm starting my first project Tele. I'm wanting to build a Nashville Style Tele. Want a Humbucker that can switch to a single coil without the 60 cycle hum of a single coil.
    Has anyone got any ideas on that?[/QUOTE]
  10. ScottyMo
    Kinston NC
    OK You guys. Here's another probably stupid question. What are the differences in the quality of the different telecaster necks? They all seem to be made of maple wood. Is there a difference in quality of different truss rods etc?
    What would be the difference between a good quality neck and a neck of less quality?
  11. Fretting out
    Fretting out Friend of Leo's
    Land of Mary
    Anything actually made by fender is usually decent so is warmoth and USACG
    Personally I’d stay away from Allparts as they require more work
    fender and warmoth truss rods are of good quality
    For the most part a truss rod is a truss rod but when you get into eBay Chinese necks they could be anything including too thin and prone to breaking
    Some necks have higher quality frets and finishing work such as rolling the fretboard edges and better overall fret work (no sharp edges , fret sprout etc.)
    How much care is taken when finishing is done can affect quality such as a nice nitro lacquer will cost more than a polyurethane finish
    Some of these faults can be seen when looking at but a lot of it is based on feel and sometimes you won’t notice high frets till it’s strung up but if you go for an actual fender neck especially USA they rarely require fret work
    I’m sorry if this isn’t too helpful it’s mostly up to feel
    I’m sure some other members can explain it better than me
  12. ScottyMo
    Kinston NC
    Thank you. Youve kind of given me some insight as to what to look for.
  13. Fretting out
    Land of Mary
    I forgot to mention musikraft necks they are just are supposed to be as good as warmoth and the other replacement neck companies but can be pricey depending on the features you get
  14. ScottyMo
    Kinston NC
    Thankyou.
  15. ScottyMo
    Kinston NC
    Hey y'all. I'm considering a 4 single coil pickup configuration. 1 in normal bridge position. 1 almost next to bridge, mounted in the pickguard which is to be switchable on/off but to work inconjuction with bridge when it's on. The other 2 mounted basically like middle and neck strat pickup. What would wiring diagram look like. Has anyone ever tried this. Tell your thoughts. (As long as they are nice LOL)
  16. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    my 2 cents:
    i have a 2 pickups guitar, humbucker bridge, single coil noiseless neck
    1 vol, 1 no load tone pot with the help off this topic
    https://www.tdpri.com/threads/no-load-mod-your-guitar-bass-tone-or-blender-pot-2014.466061/
    wiring with 4 way N>N+B>B>N+B series and a miniswitch that can
    serie/parallel the humbucker so it still stays noiseless in semi single coil parallel sound.
    the more options you will have the more you will be busy with switching and tweaking than playing.
    keep it simple would be my advise
  17. ScottyMo
    Kinston NC
    In my experience playing with bands, especially cover bands has been trying to mimic sounds from each songs, I was trying to come up with something versatile. I play sort of a Driving Country Gospel. A mixture of Twangy, Blues, Southern Rock and Slide Guitar. I have an American Standard with Nashville set up at present. Looking for something with a little bit different sound as a second Tele or Nocaster as they say.
  18. hopdybob
    netherlands
    now i never played outside my house, so no idea what you have to do to perform, but when i would have to perform a lot of songs of others (that al have there own gear and setup) i would rather chose a good multieffect so you can tweak every preset working with the guitar you have to get near that sound you will need.
    guitarsound is adding up all the things of the chain from hands to loudspeaker and that can't be done in one guitar but i know a normal tele can cover a lot
    (the voice of Holland guitarist plays a lot of music styles and electric 75% with tele)
    i don't know how your Nashville is wired up, but my strat is wired B>B+N>N>N+M>M
    with this you could get tele combinations and 1 strat quack.
  19. ScottyMo
    Kinston NC
    My Nashville is basically wired like a Strat with a 5 way switch but has a push/pull on volume knob to keep all pickups in play if needed. It's a great sounding guitar. Just looking for something a little different to widen my sound a little more.
  20. illinismitty
    illinismitty TDPRI Member
    Nashville
    I ordered a Musikraft neck. Maple neck, rosewood board, 6150 frets, 12" radius, light coat of lacquer. It was $225. Not a horrible price. If you stick to the basics, their necks are priced well if you want to tweak your specs. They also have a few different truss rod options. But their wood upgrades are pricey. I wanted a Pau Ferro fingerboard, but it wasn't worth the price to me.
