Velcro ban
4pickupguy
Fort Worth, Texas
My board is designed for and made velcro installed. All my pedals have dual lock on them the way god intended.
I do the small triangle thing so that I can remove the pedals.
dogmeat
Alaska
I dumped velcro years ago. I use links of bicycle chain. you have to take the temper out if you want to bend them. sorry, you'll have to clic on the pic to see it better
"IT'S A SERIES OF TUBES!"
....and I know who said that. bein' from AK 'n all
runstendt
Bloomsburg PA
My first pedalboard was incredibly DIY and made from a Tupperware knockoff. To secure the pedals I drilled holes in the lid matching the bolts holding the bottom onto each pedal, then used slightly longer bolts to bolt the pedals right to the lid. Those pedals weren't going anywhere. It was the only pedalboard I ever owned where I could hold it upside down and shake the board violently and nothing moved. Granted, it wasn't the easiest to modify.
radtz
Wisconsin, USA
Dude... Your pedal board is so METAL!
Wound_Up
Shreveport, LA
I use velcro to attach my causeway tag to the inside of my windshield. I find the hook-and-loop part to be much stronger than the glue itself, which can't hold up to SE Louisiana heat. Especially inside a car. You pull the tag off the windshield, and the velcro on the windshield pulls off and sticks to the tag.
I understand the Causeway Commision is coming up with a new system.
Nothing stands up to Louisiana heat lol. Not even our inspection stickers 🤣
Phrygian77
Gold Supporter
Crawfordville, FL
Velcro is pretty much as good as it gets. The whole bottom of my covered with it. Years ago I even bought these over priced plastic things to go around my vintage Boss pedals so I could put Velcro on them (my CS-2 and DM-2 for example), way before they reissued a bunch of those (no CS-2 reissue though and probably never will be).
New Posts
