Using the heat to your advantage.
Discussion in 'Bad Dog Cafe' started by G.Rotten, Jul 20, 2019.
  1. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    A while ago I ordered a Pickguard from Amazon. It showed up bent or warped.
    I complained & they sent a replacement. So a couple days ago I set the warped one in the sun on a flat table. In an hour it was flat.
    I left it for a couple more days to sun age it.
    Might give it a few more days. May not as it began to curl up a little after the 3rd day. Probably need to flip it occasionally so both sides experience the same conditions.
    Sadly, I did not take a before pic of the warp last week as I thought I still had the ones I sent to Amazon.
    Teleterr likes this.
  2. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    You could screw it to a board to keep it from warpping..
    G.Rotten likes this.
  3. dkmw
    dkmw Friend of Leo's Silver Supporter
    Florida USA
    You’ve also got a head start on any smelting projects you’ve been putting off:eek:
  4. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    Because it curled up I'm sure the Pickguard screws will hold it perfectly flat if I ever actually use it. I'm thinking one side is shrinking in sun and so I should let the other side shrink equally if I keep going. I would like the color to age a bit more. If I can get the tint just right I'll for sure use it.
  5. O- Fender
    O- Fender Tele-Afflicted
    Maybe put it on a flat surface and put glass over top of it?
    We used to do that to records back in the day.
    StrangerNY likes this.
  6. StrangerNY
    StrangerNY Friend of Leo's Gold Supporter
    Long Island, New York
    Or lay a piece of glass over it.
    - D
