mountainhick
I am looking for a specific solution for a 6v6 pair, but also to discuss three things:
1: How to come up with anticipated draw from a PP pair of output tubes in general
Uncle Doug has a youtube vid that specs out a classictone for a Deluxe AB763 where he essentially derates the 6v6 draw to
about 70% from max output current for plate and screen on the data sheet. He says based on experience, that a PP pair raws about 70ma. Is this a good sort of rule of thumb regarding deriving ratings from PP charts on spec sheets?
2: How close can you cut it when spec-ing out PTs in terms of amperage rating vs draw.
If a 6v6 pair comes out to about 70ma. Would the single 80ma coil on the antek hold up in use? Then the second lower voltage coil could be used for the rest of the tubes... more than enough current for the remaining triodes. (note: I want to apply same theory to other output tubes. I have 6aq5s and 6CM6 in mind as well)
3: The possibilty.discussion around combining non voltage matched coils, like some models that ANTEK offers:
A few of their 50VA series have dual unmatched HV outputs. An example is the AS-05T320 - 50VA 320V
Electrical Characteristics
is it possible to parallel the 320v and 300v coils? I'd expect that more current would flow through one side, but how does this work in a real world situation? Would I gain enough amperage at a middling voltage to handle the total demand?
Or the next big step up is to the 100VA series which are a bit more than double the amperage for a given voltage, with coils voltage matched. They offer 300V and 350V.
Output Voltage | Current |
Outputs | 3x |
Power | 50VA |
320V | 0.08A |
300V | 0.08A |
6.3V | 2A |
6.3V | 2A |
