Using a capo puts my guitar out of tune.
Discussion in 'Acoustic Heaven' started by telestratosonic, Dec 9, 2019.
  1. telestratosonic
    telestratosonic Tele-Afflicted Silver Supporter
    Alberta, Canada
    I used a headstock clip-on tuner to tune my Gibson J45. Then I put my capo on the second fret so I could use G Major, C Major and D Major open chords and be in the key of A.
    However, when I check the tuning, I'm out of tune. Can you experienced capo users out there give me the benefit of your knowledge on this?
    Jim
  2. SixStringSlinger
    SixStringSlinger Friend of Leo's Silver Supporter
    Space
    Could be the capo is squeezing too hard, bringing some strings sharp. Some capos have adjustable tension for this reason.
  3. clayville
    clayville TDPRI Member
    Boston
    What kind of capo are you using? I find that clamp-style capos like a Kyser tend to pull unevenly and put my guitars out of tune more than a Schubb-like capo which seems to apply the pressure straight down. For me, it's beneficial to be able to vary the tension to fit the neck at the capo fret as you can with a Shubb. Either way, I always check my tuning after applying the capo. Just my experience... ymmv.
  4. Mexitele Blues
    Mexitele Blues Tele-Holic
    Westminster, CO
    Many capos exert enough tension to press the strings all the way to the fretboard, which is enough to put the guitar out of tune. Scoot the capo up just behind the fret so that the tension doesn't push down the strings so far.
  5. charlie chitlin
    Spring City, Pa
    Yup...minimum possible tension, and touch up tuning.
    I seldom use one, but I remember placement in relation to the fret makes a difference.
  6. corliss1
    Lansing, MI
    Another +1 for adjustable like the Shubb. I was never a fan of the ones you just squeeze and let go of for this reason.
  7. vid1900
    vid1900 Tele-Meister
    usa
    Don't put it dead center, move it forward until it almost touches the fret
  8. Jim622
    Jim622 Friend of Leo's Silver Supporter
    Philly
    I always tune after putting a capo on. I figure it’s just how it is.
    Owenmoney, Viejo, nvilletele and 3 others like this.
  9. brokenbones
    brokenbones Tele-Meister
    Indy
  10. telestratosonic
    Alberta, Canada
    Thanks all!
    1) I'll try putting the capo right behind the fret; I've been putting it behind the fret 1/4" (6mm) or so.
    2) I have a new USA-made Kyser and yes, it sharpens the pitch, especially on the high E and B strings.
    3) I'm familiar with the Shubb and will research it.
    4) I'll retune after putting on the capo.
    Tonetele likes this.
  11. telestratosonic
    Alberta, Canada
  12. popthree
    popthree Poster Extraordinaire
    a hawk makin lazy circles
    All capos will pull the guitar slightly out. Retune.
  13. PeterUK
    PeterUK Poster Extraordinaire Silver Supporter
    Nottingham, UK
    This. ^^^^^^^^^^^^^^
    Bill Kirchen used my Dano Bass VI at a gig and popped a capo on and retuned.
    If Bill retunes, that’s good enough for me.
    :) Peter
  14. EsquireBoy
    EsquireBoy Tele-Holic
    Paris, France
    Plus it tends to ruin your frets if you use such a capo often enough. A capo with adjustable tension is the way to go.
    telestratosonic likes this.
  15. jhundt
    jhundt Doctor of Teleocity
    Netherlands
    this brings us back to the never-ending story about how the first 5 frets of a guitar are always wacky out-of-tune.
    It is a fact; it can be corrected to some degree with a compensated nut.
    12th-fret intonation has nothing to do with it.
    A perfectly-cut nut doesn't help.
    Different gauge strings won't fix it.
    Even the lightest capo tension won't help (though heavy tension can certainly make it worse!)
    It's just a fact.
    Many guys here do know know this; or they do not believe this. The answer is, as mentioned above, that you have to check the tuning after placing the capo if you are in a critical-tuning situation.
  16. telestratosonic
    Alberta, Canada
    Thanks all for the info and suggestions. I like the Shubb Fine Tune capo and the Deluxe capo for steel string guitars. I'm going to try them out this Friday when I go to Edmonton.
  17. RoarDog
    RoarDog Tele-Meister
    Null
    I've had this issue, for me it was a combination of tall frets and too much tension from the capo. Seems counterintuitive but slightly raising my action helped a lot.
  18. Octorfunk
    Octorfunk Tele-Meister
    Midwest
    +1
    Also, I saw a video once that was very helpful.
    After putting the capo on, grab each string in the middle (between the capo and bridge) and give it a decent upward tug away from the fretboard. Not too hard, but enough that it comes off the fretboard about an inch. Your capo is pinching the string and most likely causing it to go sharp. By pulling in the strings after capo-ing, you are getting that bit of the string that is caught up in the rubber of the capo and pulling it back out. You will probably still need to tune a bit after doing this, but I can almost certainly guarantee you that if you just capo and then tune immediately, after playing for a bit the strings will naturally start to release from the rubber of the capo and go sharp/flat.
    If instead you capo close to the fret, stretch them, THEN tune, you are going to get the most consistent results.
  19. colnago
    colnago Tele-Meister
    The Great White North
    Either your capo is squeezing too hard or your nut slots are too high. A capo will put it out of tune slightly, it’s an inherent design flaw.
  20. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    It will always pull you at least a little out of tune, in part because putting it on moves the strings a little side to side in addition to clamping down. I always retune after moving a capo. I my current project I'm capoing a bunch at 2 - I think I'm just going to have one guitar on capo 2 and one no-capo for gigs, faster to swap guitars than constantly retune.
