USA vs. Mexico Tremolo Units?
Discussion in 'Other Guitars, other instruments' started by Bob M, Nov 15, 2019.
  1. Bob M
    Bob M Tele-Afflicted Ad Free Member
    North of Boston
    I have a Jazzmaster and Jaguar. I really have bonded with both. The only issue I have is with the tremolo in the Jaguar. I assume it is a MIM unit. It is stiff and not as smooth as the unit in my Jazzmaster. The JM unit is clearly a different part-it ha s the slide "lock" switch-the Jag unit doesn't have this switch. Is a MIA unit a direct replacement? Any help will be appreciated.
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Yes, but you may have to slightly enlarge the body route where the lock fits. Otherwise it's a boltin fit
    Looking for tuning stability?
  3. Bob M
    North of Boston
    No, the tuning is good. The unit doesn't operate as smooth as it should IMHO. I really haven't explored adjustment yet. Any advice?
  4. Dacious
    Godzone
    It's worth using some solid lube on the pivot points. I had two JMs and I remember adjusting the spring had a lot to do with how smoothly they released and return to pitch.
    Chapstick (natural) actually makes a good lube for contact points, it doesn't attract dust.
    This is not a bad guide.
    https://www.premierguitar.com/articles/25516-diy-how-to-set-up-jazzmasters-jaguars?page=4
  5. Bob M
    North of Boston
    Great info. Much appreciated. More complicated guitars than Teles for sure!
