Updates on 81 Pro Reverb problems
Discussion in 'Amp Tech Center' started by Axer57, Sep 28, 2017.
  1. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I pulled each preamp tube 1 at a time and tried it. It's still there to some degree with all. When I touch V2 though it's completely gone . It's the same even with no instrument or cable plugged in. Guess I need to check connections and re solder V1 , V2 , and V3.
  2. corliss1
    Lansing, MI
    So you said it goes away when you touch the heater wire - do you mean touching the ping with something metal, or just touching the wire with a finger or what?
    Reflow the heater connections there to see if that does anything.
  3. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    It was the heater wires. I reflowed all of them from the PI tube to V1 and the hum is gone. guess I need to slow down sometimes and take each connection 1 at a time and ensure that it's a good connection.
    Impatience has always been a big problem of mine.
    robrob likes this.
  4. D'tar
    D'tar Friend of Leo's
    WNY
    If I were to replace all those sockets I would be sure to wire the preamp tube heaters in phase with each other..... V1 p4/5 to v2 p4/5, v1p9 to v2p9... Etc...
    Not saying this is your issue, just sayin:)
    I have seen them not like this and still quiet. From the pictures there is plenty of oportunity for lead dress induced noise. Some time with a chopstic may be beneficial.
  5. corliss1
    Lansing, MI
    Yay! Glad it was an easy fix!
  6. D'tar
    WNY
    Ahh....
    Glad you got it....
    Every connection counts right!
  7. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I do have all the heater wires wired exactly as you described D'tar.
    there was just so much wrong with this amp when we started I guess I got in too big of a hurry. This is one case where I should sweat the little things...lol
    This is the first time I've ever gone this deep in an amp. I have replaced parts and tested many times but never with so much to test and replace at one time. I have learned a ton of good things on this one .
  8. corliss1
    Lansing, MI
    And THAT is the best part of it all - you learned something. Sure, the amp sounds great, but *you* did it and made it happen.
    Now the next amp where you have issues you can knock it out in a couple hours :D
    D'tar likes this.
  9. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I should have come here first 11 months ago with the original problem. I love the fact that it's Blackfaced but the tech is probably out quite a bit money for the parts.
    I'm just glad it's working right now.
  10. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I've noticed , since I removed the braided covering from the 2 input and 2 volume pot wires. If I touch them it produces alot of hum. Any recomendations for better wire at these spots?
  11. corliss1
    Lansing, MI
    Nah, that's pretty normal, unless you plan to be touching wires in the amp while playing.
  12. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    LOL...in my younger days I did some dumb things " just to see what would happen" . Not anymore. It cost me a Fender Princeton...
  13. D'tar
    WNY
    I agree, not necessary....
    If you must... RG174
    clintj and corliss1 like this.
  14. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I replaced the input wires with some good wire and put it all back together. Played on it off and on all all day yesterday. It sounds great and idles very smoothly . Thank you to everyone. I couldn't have done it with out you.
    D'tar and corliss1 like this.
  15. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    Well I thought I was done , but I do have another question. When I turn the volume on either channel. I get nothing until I reach 2 1/2 on the pot. Then I get a weak muffled sound as I reach 3 on the pot it comes on sounding great but at club level. I have read that this is because the original BF pots were 30% and the new ones are 10%. The only 1MA 30% pots I have found online are from mouser , they are Alpha[Taiwan] . Would these pots even out the volume or is this just another wild goose chase.
  16. justin.ramsey
    justin.ramsey Tele-Holic
    Northern, KY
    Measure the resistance of the pot as you turn up the volume to see if it's working appropriately
  17. Axer57
    Axer57 Tele-Meister
    Albion , IL.
    I put all new CTS pots in the amp. I tested them all before installing them.
  18. robrob
    United States
    What you describe shouldn't be caused by good 10% pots.
  19. corliss1
    Lansing, MI
    can someone enlighten me on what the pot percentage means? this is a term I haven't heard
  20. robrob
    United States
    I believe it's the % of total pot resistance at 50% throw. 10% would be more logarithmic than a 30%.
    clintj and D'tar like this.
