Upcoming parts caster idea - am I crazy?
Discussion in 'Tele Home Depot' started by Jim Sams, Dec 12, 2020.
  1. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    I always loved the old Hamer Prototype/phantoms. When I had one, I thought they a good a job as anything to have Gibson and fender tones.
    I have always thought about building my own parts caster version. I have the later Phantom Duncan bridge single coil and the three coil pickup mounting ring. The later versions used a JB but I might use a Duncan 59.
    My thoughts are to use a mahogany Tele Paul body, with a,humbucker route in the bridge and a single coil route in the neck. Then rout the bucker route out to triple coil size.
    From my recollection, the neck single sounded pretty much like a strat neck pup. I have a line on a real Duncan phantom neck pup but I wonder if it is worth the premium as I have several good strat pups laying around I could use.
    I am thinking of using a warmoth mahogany conversion neck.
    The bridge will be a wraptail.
    Since this is following the spirit of the Hamer, any reason this will fail if I do my job?
    crazydave911 likes this.
  2. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Attached is a pic of the body. I need to route the bridge pickup position for the triple coil.
    nnieman and crazydave911 like this.
  3. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Ok so I got the router out...
    E1BAD30B-749F-4EB4-82D8-E4CE4776CAD2.jpeg 45BA2C8F-7E3A-499C-B02D-528EF56D8C56.jpeg
    triple coil ring is from frets on the net, single coil from Josh Gravelin
  4. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    I think I’ll put forearm and belly contours on it next....
  5. crazydave911
    East Tennessee
    Of course you're crazy, you're here :)
    Dave
  6. Ronkirn
    Jacksonville, FL
    welcome to the loony bin... we don't hafta make excuses, we just Dooit..
    rock on..
    r
  7. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Ok I took a Shinto rasp to a perfectly good body....I really need a better way to hold the body to my little welding table.
    Anyone have any cheap clamp ideas? I think I’ll take off a little more on the forearm area. Since the bridge will be higher off the body than a strat, I don’t think I’ll need to go crazy with wood removal
  8. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Cool project!
    A cheap clamp idea?
    Sure. Take some scraps of plywood or two-by whatever and fasten them together at a right angle to make a clamping fixture.
    You can clamp one side of your "clamping fixture" to your table and then clamp the body to the other "wing".
    You can make your "clamping fixture" very rigid by fastening a block or two of scrap wood between the "wings" to stiffen it up.
    Having the body in a position that makes it easy to work on takes most of the "work" out of the job and lets you concentrate on the best part of the job :).
  9. 2HBStrat
    2HBStrat Tele-Afflicted
    Four Rivers Area of Middle America
    Those exceptionally thin Hamer pickups
    really sound good. Really Stratty...
  10. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Making progress with the finish. Whitewash then black timber mate filler
    nnieman likes this.
  11. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    Those Hamer Prototypes are fun and have been on my someday-to-build list.
    Another in a similar idea is the Robbie Robertson Strat with the middle pickup pushed back to the bridge pickup for 'HS' but has a regular 5-way with a push/pull series humbucker option. Fender launched a Squier model similar to the RRS but a different 5-way wiring scheme without the push/pull.
  12. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    They are really wound on. Hum bucker bobbins with rod magnets shoved through the bobbin. The magnets stick out of the bottom of the pickup Quite a bit
    2HBStrat likes this.
