Unusual diodes on 62 Princeton reissue
Discussion in 'Shock Brother's DIY Amps' started by Uncle Daddy, Apr 15, 2021.
  1. Uncle Daddy
    Uncle Daddy Tele-Afflicted
    Maldon, England
    I've been looking over some pics of the Chris Stapleton 62 reissue and noticed a diode on each of the 6v6 sockets, running from pin 3 to 7. Any ideas what they do?
    Interesting how there's no twisted heater wires.
    fidopunk likes this.
  2. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    They provide fault protection if the amp is run with no speaker load.
    Uncle Daddy likes this.
  3. TwoBear
    TwoBear Tele-Holic
    oc. CA.
    I see it’s tube rectified, Are they not a fail-safe in case the rectifier goes? I also see a fuse available outside, seems to be for the Mains, as usual, And then there also seems to be a fuse on the heaters the green wires, and also a fuse on the yellow, which should be the rectifier?
    Is this a copy of the black face Princeton that came out with white knobs originally? I think it was volume, tone and maybe speed and intensity for trem? if so that was an absolute Lil killer! I played in a band with a singer songwriter sort of John Hiatt type of guy who played one with the Tele, while I played my silverface Princeton. I had always gotten compliments about my tone, But his was easily way nicer sounding than mine
  4. XTRXTR
    XTRXTR Tele-Meister
    Northern Colorado
    I'm guessing there is no twisted wires because they rectify the heaters.
  5. Uncle Daddy
    Maldon, England
    Those fail safe diodes are normally fitted on the rectifier socket. These are on the power tubes.
    Yes, it's a Custom Shop replica of a 62 Princeton.
    robrob and NSB_Chris like this.
  6. Uncle Daddy
    Maldon, England
    They shunt the OT to ground?
  7. danlad
    danlad Tele-Meister
    Here and there
    They look to be flyback diodes to protect the output section from high voltage spikes from the output transformer. Never seen them referenced to ground through the heater winding though.
    printer2 and Paul G. like this.
  8. NSB_Chris
    NSB_Chris Tele-Meister
    New Smyrna Beach Florida
    I don't see that they are rectifying the heaters. One heater tap of the secondary goes straight to a chassis ground lug, and the other goes through the fuse, pilot and then to one side of the socket heater connections. The other socket heater connections (pin 9 of the preamp tubes and pin 7 of the power tubes) are all chained and landed to another chassis lug. Looks to be true to the original except rather than grounding one socket heater connection right at the socket like I think the original did, they collected them and grounded at one point. The 6V6 plate diodes are connected to the most convenient ground connection point which is the grounded heater pin.
    Nickfl, robrob, danlad and 2 others like this.
  9. lathoto
    lathoto Tele-Meister
    Ohio
    Enjoy that amp. One of the best amps Fender has released in a long time and probably the best reissue ever!
  10. Uncle Daddy
    Maldon, England
    The cap on the trem jack socket- is that to prevent switch pop?
  11. Urshurak776
    Urshurak776 Tele-Afflicted
    Charlotte
    Wow. If fuses pop you have to break out the soldering iron?
  12. Uncle Daddy
    Maldon, England
    Just came across this-
    OUTPUT SPIKE PROTECTION
    This modification involves taking three 1N4007 silicon diodes in series with the banded end connecting to pin three of your output tubes and the other end to ground. You use one on each side of a push-pull output. So for example, on a 100 watt Marshall the two tubes on the left, either pin three of either one of those tubes can connect to this diode to ground. And on the other side either pin three can connect to the other set of diodes to ground, as the tubes on either side are in parallel.
    We use 1N4007 silicon power diodes which are effective in suppressing spikes at certain frequencies. These will not necessarily prevent spiking on all amps! There is a fast recovery or high speed diode which will suppress higher frequency arcing however these diodes have a very distinct disadvantage as they alter the tone of the amp! They make the amp sound muddy as they bleed off high frequencies from the output transformer! Trainwreck does not use these kinds of diodes because of their effect on the tone.
    While the Trainwreck method does not eliminate spiking in every amp, it does not effect the tone at all. Every other method which will totally eliminate spiking will have a negative effect on the tone of your amp.
    Another point to remember concerning spiking is that hot biased amps tend to generate more high voltage spiking than properly biased amps.
    https://ampgarage.com/forum/viewtopic.php?t=30328
  13. danlad
    danlad Tele-Meister
    Here and there
    Makes sense now! I had assumed a centre tapped heater winding.
  14. robrob
    United States
    When people tell you that you must twist your heater wires tightly and use 1% 100 ohm resistors for the artificial ground to keep the voltage equal refer them to a chassis pic of this reissue amp. Have them glance at the heater wiring of the very high gain Soldano SLO too.
  15. Uncle Daddy
    Maldon, England
    Isn't that a centre tap to the transformer bolt?
    What do you make of this diode and resistor?
  16. schmee
    schmee Doctor of Teleocity
    The heaters are just single wires like some old Fender amps, the other side grounding through the chassis... right? There are no second set of wires to twist.
    Looks damn nice for a modern Fender. They ought to do more like this if they want to be a cut above the rest like they used to be.
    robrob likes this.
