Mike Caffrey
With a standard 3-way switch and without push/pull or mini toggle, is it possible to wire two humbuckers so that you get position 1 split, middle both humbucking and 3 split?
I've "tuned" my humbuckers by auditioning resistors for partial splits so that they end up in between humbucking and single coil, and brighter, but still have some noise cancellation. I don't want the option to switch between humbucking and tapped when each pickup is alone, I don't like the sound of the middle position when both are split, and I'm happy with the sound of the two in parallel as humbuckers.
Right now I've got a single push push, but I don't like having to both move the switch and hit the push push. Plus, I want to use the push push to bypass the tone.
For those interested in all of the details, I've got a large cap in series with the resistors for the bridge so that the low frequencies and 60hz are still humbucking, but the highs aren't canceling and end up more open and single coil sounding. The neck doesn't have the cap, just the resistors.
Seth Lover in the neck and BG1400 in the bridge.
If there's no way to do this, where can I find a double wafer 3-way in the US?
