Untouched Original ‘67 Bassman AB165
Discussion in 'Shock Brother's DIY Amps' started by Skish, Feb 9, 2020.
  1. Skish
    Skish TDPRI Member
    New England
    Just had a friend bring me an amp he picked up recently to have a look. Said it didn’t sound great. I’ve built a few Tweed clones and repaired some solid state amps. But I was pretty excited and a little shocked to see a completely untouched AB165 Bassman. I haven’t plugged it in yet, I immediately ordered a set of Electrolytic caps and a new matched pair of 6L6s. (Current powers tubes are different brand and style). While waiting for the caps, I was looking it over and noticed “warts” on the current caps. Are these normal or are they breaking down? Anyone seen these before?
  2. David Barnett
    The "warts" are completely normal, for a capacitor that is failing. That's the electrolyte getting ready to spew its guts all over the inside of the amp.
  3. Ten Over
    Ten Over Tele-Meister
    Central California
    I surely would love to see some more pictures.
  4. Skish
    Skish TDPRI Member
    New England
    Thanks David. That’s what I suspected. I hadn’t seen these old caps before so I wasn’t 100% sure. I figured it was dangerous to plug them although it has been played recently by someone else.
    sds1 likes this.
  5. Skish
    Skish TDPRI Member
    New England
    Sure...just some of the insides for now. I’ll have the caps in a couple days and get it reassembled. I washed up the tolex, it had a few years of grunge.
    I need to pickup the cab and give that a look too. Only have the head right now.
    FenderLover, Vibrolux59 and Jlwctn like this.
  6. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    The only filter cap I've ever blown up was one of those in a '67 Bassman.
  7. jguitarman
    jguitarman Tele-Afflicted Silver Supporter
    No CA
    It'll be interesting to see if it has the original speakers or replacements. These are great amps but don't get the love they deserve because of the large speaker cab. I put a brown face Bandmaster head in a custom blond cab with a 15" speaker to make it gigable. Both the Bassman and Bandmaster amps can be bought for relatively little money and are wonderful vintage amps.
    Greggorios likes this.
  8. David Barnett
    "IP" for a date code seems unlikely, that would be the 16th month of 1959...
    If that were reversed, it would be 9th month of 1966, which seem plausible. Did they ever do the date code letters backwards?
  9. jguitarman
    No CA
    Can't say that I ever saw backwards date codes but they sometimes put the wrong tube chart on the wrong amps so I'd bet it was a mistake. CBS even produced some early Bandmasters with the word Columbia misspelled before they realized the error.
  10. Skish
    Skish TDPRI Member
    New England
    I think the part of the date code that looks like an I is the left edge of the stamp. And the second letter is actually very light and cutoff. It looks like possibly a “C”.
    Wally likes this.
  11. Skish
    Skish TDPRI Member
    New England
    Can’t believe I hadn’t looked up these date codes on the tube chart before. So this is apparently a 66 not 67.
  12. David Barnett
    Good spot.
  13. Paul G.
    Paul G. Friend of Leo's
    Rhode Island
    Is the faceplate silver or black? If silver, are there black lines between the channels?
  14. Paul G.
    Rhode Island
    Those electrolytics on the board should probably be replaced as well. Get five 25uf/25V electrolytics and change 'em. Those 3 big cardboard-looking things -- two of em are dual caps, but just replace them with regular singles.
    Do you know how to discharge caps and check? If not, you need to take the time to learn.
  15. corliss1
    Lansing, MI
    And now you've seen what every vintage Fender looks like with caps that are long past their sell-by date :D
    Paul G. and AlbertaGriff like this.
  16. Skish
    Skish TDPRI Member
    New England
    It’s a blackface. I’ll post more phots soon.
    I did order caps for the inside as well. Mostly F&T. They had dual caps so I ordered those to keep it the same.
  17. Skish
    Skish TDPRI Member
    New England
    I should mention, I also order 1W metal oxide power resistors to replace those as well. I’ve often seen those included in the cap kits and assumed it should just be part of the job.
  18. Wally
    The SF cosmetics did not begin until April, 1967.
    plus one on the date code being either PC or PG....PG being March, ‘67 and PG being July of ‘67.
    Nice amp....if he is lucky, there are Jensen C12N’s in that cab. If the speakers are 12T6 Oxfords, they are low efficiency speakers....and that might be a good thing if the owner wants to push the amp without blowing out windows.
    Skish and Paul G. like this.
  19. David Barnett
    Were they still fitting Utah speakers in Bassmans at that time too?
  20. Ten Over
    Central California
    Thanks. I appreciate it.
    This amp is almost certainly a 1966, probably in March. "P" on the tube chart is 1966 and there is a date code on a capacitor from the 48th week of 1965.
    Skish likes this.
