gmm52
I know that tube amps want to see a load and that they shouldn't be turned on without a speaker connected, but what about standby? Can one safely unplug and change cabinets while an amp is on standby?
Yes, this is the characteristic when the standby's hit. The amp is a 50w Marshall clone, a hybrid, JCM800 preamp section with a JTM45 power amp section.Play and listen when switching Stby Off. If you hear volume quieting while usually also distorting it means Stby remove high voltage and tubes use the energy from filter capacitors and it is very safe to change loudspeaker/cabinet
Here's the thing. I want to do extensive cabinet testing, and my assumption is powering down completely, repeatedly, when changing cabs would only take mere seconds seems more taxing on the amp than using just the standby.There is zero advantage of using standby instead of mains power to switch cabinets, and as @rdjones noted it, not all standby circuits work the same way.
(Dons preacher robes, waves arms): Can you handle the truth? There is zero advantage of standby at any time:
http://www.valvewizard.co.uk/standby.html
I do lots of speaker testing and have built all my amp and know that second switch removes the High Voltage. Then continuing playing few seconds deplete capacitors fast and there is no need to switch Mains Off for loudspeaker change.Yes, this is the characteristic when the standby's hit. The amp is a 50w Marshall clone, a hybrid, JCM800 preamp section with a JTM45 power amp section.
You can play it safe in the long run and... Protect yourself against the mistakes you might do on the future by adding a switching jack that switches to a load resistor when no cab is plugged in, its like a 15 minute job once you have the jack + power resistor:Here's the thing. I want to do extensive cabinet testing, and my assumption is powering down completely, repeatedly, when changing cabs would only take mere seconds seems more taxing on the amp than using just the standby.
