Unpleasant distortion in 6G2 Princeton
Discussion in 'Amp Tech Center' started by AlbertaGriff, Apr 11, 2021.
  1. AlbertaGriff
    AlbertaGriff Tele-Afflicted
    Hi all,
    I know I've been asking a lot of the forum but I need a bit more help.
    After doing the cap job on my '62 Princeton, I noted the trem didn't work at high volumes and there was an unpleasant distortion in the decay of notes when using the trem. After checking the bias, I noticed it was down around 30%. I installed the bias adjust and got the bias up to around 63%.
    Now the trem works GREAT! But the unpleasant distortion remains.
    I've tried to record it. First I'm at volume near 6 with trem on 10. The distortion is audible to me, but not so much in the recording. Then I turn trem off so you can hear the normal overdrive. Then at the end I lower volume to around 3.5 and turn the trem back on. This is where you can really hear the unpleasant distortion.
    Listen to Brownface Princeton distortion by AlbertaGriff on #SoundCloud
    https://soundcloud.app.goo.gl/aeHNo
    What I've done to the amp:
    -Replaced bypass caps
    -Replaced filter cap can
    -Replaced bias cap
    -Installed bias adjust pot and set bias to 63%
    Pick_n_Strum likes this.
  2. theprofessor
    Chattanooga, TN
    lathoto and AlbertaGriff like this.
  3. AlbertaGriff
    I could certainly try that! Thank you.
  4. dan40
    dan40 Friend of Leo's
    Richmond Va
    Does this problem only occur with the trem switched on? Does the overdriven tone sound fine with the trem off?
  5. AlbertaGriff
    It's 'sort of' hard to tell. I don't think I hear it with the trem off.
    Definitely at lower volumes, the distorted tone is only there when the trem is on, and at a high setting.
  6. dan40
    Richmond Va
    That's strange. I'm guessing that this problem didn't exist before the cap job and the bias pot mod. Have you tried rotating through different valves to rule those out first? A list of all voltages throughout the preamp and power amp may help to narrow down the possibilities.
  7. AlbertaGriff
    Actually it was there prior to the rebias. I just hoped it would go away once the bias was set better.
    Prior to the cap job I can't really say, I didn't play it too much.
  8. AlbertaGriff
    Maybe I'm hearing more here than there really is...
    I compared to my 5F11, and I could hear some of the distortion I'm talking about here with the 6G2, but probably a third or half of the volume.
    Also, I was just playing at the lower volume, with trem intensity maxed, and I didn't hear any of the distortion. Could be that it only happens after bringing the volume back down from nearly cranked...
    I'll dig a bit more.
    dan40 likes this.
  9. theprofessor
    Chattanooga, TN
    If it's only happening with the tremolo engaged, I'd tend to think that the bias is still too high for a bias-vary tremolo amp. My 6g2 would distort when the tremolo engaged, until I got the bias down a bit more. With these amps, you've got to balance the sound of the tremolo (distortion) and the overall sound of the amp. Try something like 55% mpd and see what happens.
  10. AlbertaGriff
    Yeah that's a good suggestion.
  11. AlbertaGriff
    I went down to between 50% and 55% and unfortunately the problem remains.
    I'm wondering if it's actually present when the trem is off, but is just less noticeable because of the rest of the signal. Wondering if it's a bad cap or resistor somewhere along the line.
    theprofessor likes this.
  12. theprofessor
    Chattanooga, TN
    Well shoot! Sorry that didn’t fix it!
    AlbertaGriff likes this.
  13. AlbertaGriff
    Don't apologize, I appreciate the thought and suggestion. It was definitely worth a try.
  14. AlbertaGriff
    Here's another recording. Volume is around 4. Starts off with no trem, it's an idea of the clean tone. Then I crank the trem to 10. The distortion is quite audible after the chords... it's like a ghost note in the decay.
    Listen to 6G2 Princeton Distortion #2 by AlbertaGriff on #SoundCloud
    https://soundcloud.app.goo.gl/43Dsc
  15. theprofessor
    Chattanooga, TN
    I'm no expert, but I'm going to think a bit more on this. One good thing, though: the clean tone of that amp is fantastic!
  16. AlbertaGriff
    Yeah the tone overall is great, but the distortion on the trem is quite noticeable when I dig in.
    The sound reminds me a bit of a problem I had with my SF Bassman, which ended up being a bad screen resistor on one of the power tubes.
  17. lathoto
    lathoto Tele-Meister
    Ohio
  18. AlbertaGriff
    They are JJs and they are reasonably paired. I tried briefly with another pair of JJs and had the same problem.
  19. Lowerleftcoast
    california
    Did you put in that 470K grid stopper @theprofessor suggested?
    It could be a bad part somewhere along the line but...
    Essentially the tube gain stages are the same as a 5E3, but the 5E3 uses a 12AY7 and has the two volume pots and one tone pot bleed off over 90% of the signal. This thing isn't bleeding off anywhere near that. Ime you are slamming it even with the volume at 3.5 on the dial. That blocking distortion pops up it's ugly head. That 470K grid stopper should be in place imo. Maybe drop the .02uF cap before the PI to .0033uF. Maybe drop the 220K screen grid stoppers down to 130K to 180K. Maybe try a 12AY7 but the tube won't get you there alone.
  20. AlbertaGriff
    I haven't yet tried the grid stopper yet but I will sometime this week. I've got the kids at home on self-isolation from daycare so time is a luxury.
