Under My Thumb
Discussion in 'Bad Dog Cafe' started by Bill Sheehan, Mar 6, 2021.
  1. Bill Sheehan
    Bill Sheehan Tele-Holic
    Central Illinois
    If I had my 'druthers, I'd play strictly with my thumb. Both acoustic and electric. When I sit quietly in my living room I can do it just fine, and my good old thumb has a great sense of rhythm and dexterity and, especially, control, and that's a great feeling. And so liberating not to have to worry about the pick. I can't exactly "shred", but I never could anyway; with my thumb only, I can navigate any rhythm and most lead lines (for the material I usually do) without any problem.
    BUT, when I go to play in any kind of setting where we generally need to project a little better, with or without an amp or mic-up, and it's time to use a little more aggressive attack, it just sounds so darn MUDDY! Especially thumb-strummed chords! I find this to be true, for instance, with the duo I have with a friend of mine. Personal practice is typically thumb-only, and I love it; but when it's time to play together, that just doesn't seem to cut it, and I'm fishing for the pick!
    I often wonder, if I just keep at it, and keep at it, that maybe eventually that sweet spot on my thumb will develop into a rougher surface and start to sound more crisp, and less mushy? Any thumb-only players out there who might have any encouraging thoughts?
    telestratosonic likes this.
  2. Manual Slim
    Manual Slim Friend of Leo's
    Up around the bend
    I think you’re on to something with the sweet-spot callus formation but that probably won’t ever sound like a pick. EQ/tone knobs can help make things less muddy.
  3. buster poser
    buster poser Friend of Leo's Platinum Supporter
    Tewa Land NM
    My understanding is that Josh Homme didn't even use a pick his first couple of years of playing. Still doesn't sometimes like below, sounds pretty solid to me (esp for that little Gibson parlor box). I think you're always going to have a diminished attack even if your skin toughens up, but whatever you're most comfortable doing is usually always going to produce good sound.
  4. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    I haven't used picks in lots of years. Your hand and playing adapt, if you want to go that route. I can't go back to using a pick.
    Your knobs will be 8n different places without a pick, I've noticed.
    Bill Sheehan likes this.
  5. fretWalkr
    fretWalkr Tele-Meister
    DFW
    Playing with the thumb? Wes does things using his thumb that I can't believe is possible. I'm watching him do it in a live video and would never have guessed that sound could come from just using your thumb. Check out his solo around :40
  6. WorkbenchJohnny
    WorkbenchJohnny TDPRI Member
    Washington DC
    Thumb? I think Slim is on to something with the EQ thing. Especially with a +/=7 band EQ pedal to really taper those mids and reduce gassy-woof to cut through a noisy barroom.
    There are pro-level guitarists primarily using a bare thumb in loud live bands, so it’s proven possible without a pick.
  7. _MementoMori_
    _MementoMori_ Tele-Holic
    The Bible Belt
    This handsome BASTARD.
  8. WorkbenchJohnny
    Washington DC
    Also, which part of your thumb are you predominantly using?
    If it’s not the flat side / 1st knuckle, but more towards the tip than you could grow your thumb nail out a bit. I used to do that for classical guitar. It does require a different arm position so I’d ignore this option if you don’t play the thumb tip already.
    Another option are über low profile thumb picks. I like the bumblebee ones and similar. They’re just a small jazz pick attached to a thumb mount. There’s also banjo “speed picks” that are merely a slim tang. You could play one as-is or trim the tang shorter so it only sticks out enough to catch the strings
  9. buster poser
    Tewa Land NM
    Great call on Wes, was watching the below the other night, can't believe I didn't think of it first.
    It's really annoying isn't it? Snapped this about 15 years ago in DC, dude's getting better looking with age.
    Bill Sheehan and _MementoMori_ like this.
  10. burntfrijoles
    burntfrijoles Poster Extraordinaire
    Somewhere Over The Rainbow
    I thought you were going to talk about one of rock’s most sexist/misogynistic songs ever by none other than the Stones.
    Onto the subject, I play better with my thumb, both rhythm and single note. I can play faster, with better rhythm etc. Yet, I still persist in trying to play well with a pick.
    I’ve developed a technique that works for me to minimize the effect of the thumb on tones.
    I should give up on the pick.
    Bill Sheehan and WorkbenchJohnny like this.
  11. _MementoMori_
    The Bible Belt
    It's just not fair. Dude got all the talent AND all the looks.
