DavidP
I just noticed that the brass spring anchor screw in my Bill Bores unit is pulling/tilting to one side.
I'm not sure how stable it is in this condition before it pulls out completely, so am considering preventive maintenance options.
Option 1: spring tension is ok as-is, but maybe I plug the screw hole with a dowel and reposition 1/4" toward the front into pristine wood.
Option 2: completely drill out the screw hole to a slightly larger diameter and put in a hardwood dowel the strongest wood glue out there and then redrill in the original position.
Anyone else encountered this issue and successfully resolved it?
Thanks, D.
Thanks, D.
