bgmacaw
I've been considering another build of some sort and I happened to be perusing the GFS site and noticed this Burns Bison 66-ish body in their closeout section. After some consideration, I decided to order it although the weird body cavity might present some challenges. I don't think I'd be able to find a "Rez-O-Tube vibrato unit" to fit in there. I guess I'll fill it in and use some kind of top-load bridge. If you have some ideas on what to do in this area, other than fill it in, let me know.
I won't be putting Burn type pickups in it. To use something I have on hand, it will probably be a pair or trio of mini-humbuckers. For that, I obviously will need to rout some. I also have some nice Strat style single coils available if I decide to go that direction.
For the pickguard, I'll custom cut some birch plywood. As for the color to repaint it, I'm thinking about a Dupli-Color MetalCast in either purple or orange copper. I'm not sure if I'll do the pickguard the same color or something else.
As for the neck, I'm not sure yet. I don't think I'll be able to find a 24.5" scale neck at a good price. So, since I have a lot of space at the end for bridge and pickup placement adjustment, I might go with a 25.5" neck. I had good luck with a KMise neck on another build so I'll have to see what's available now.
I'll post updates as the project progresses...
