Question 1: What was the (most common) 'native' output impedance of the 5F2a? Complex but informative answers in this 2015 thread suggest to me it was (most often) 8 ohms, though, Fender being Fender, 4 was also possible, especially in late production.
Question 2: If it *was* 8 ohms, and yet the 5F2a kept the 5F1's 22K NFB resistor, then of course that's an obvious reason the 5F2a is somewhat less wild and wooly than its little brother. And also the obvious reason folks like to bump up the Princeton's NFB resistor, often on a switch, to get a little hair back, noting a full cut is pretty extreme.
Which also suggests a possible answer to the common question of how much to bump up that resistor. Rob's "Whole Earth Catalog" of amp knowledge disguised as a 5E3 mods page tells us that "When changing the feedback source from one output transformer secondary to another you change the feedback resistance by a factor of 1.41 for one step change (for example going from a 2 ohm speaker tap to 4 ohm)"... where 1.41 of course is SQRT(2). If so, and if I'm right, to get Champ feedback in an 8-ohm Princeton you'd want about 30-33K? I get the feeling that values up to 50K are often used, especially if on a pot.
