Two delays: Quarter note & Dotted eighth
Discussion in 'The Stomp Box' started by teleworship21, Dec 20, 2013.
  1. teleworship21
    teleworship21 Tele-Meister
    Ohio
    How would you guys set out to do this? I've looked at the Eventide Timefactor that could do this, as well as the Strymon and Boss DD20. Would using two DD5's or a DD5 and a DD7 accomplish this task if one had a tap tempo? I'm trying to get that rhythmic quarter and dotted eighth delay thing that's popular in modern church worship...
    Any thoughts?
  2. waparker4
    Philadelphia, PA
  3. teleworship21
    Ohio
    Oh yeah I forgot about the repeater! That would do the trick. I didn't know if having two separate delays worked better or not..
    Sent from my iPhone using TDPRI
  4. asatbender
    asatbender Tele-Holic
    Calhoun, GA
    Flashback also can do both at same time.
  5. teleworship21
    Ohio
    The regular flashback or the X4?
  6. SwampFuzz
    SwampFuzz Tele-Holic
    This Side of the Gates
    The DD-20 can do them but not at the same time.
  7. GKrakin
    GKrakin Tele-Meister
    VA
    Used to do it with two DD7s and a tap tempo. Now I get it done with a Visual Sound Dual Tap. Super easy.
  8. BigDaddyLH
    BigDaddyLH Tele Axpert Ad Free Member
    Kelowna, BC, Canuckistan
    Both. See the leetle switch on both of them for quarter/dotted-eighth/ quarter+dotted-eighth? Set it to the last.
    [​IMG][​IMG]
    There's an example of using that with the "tape" setting for a reverb-like effect, 8:30-9:30
  9. teleworship21
    Ohio
    Thanks everyone for the input!
  10. Vivi
    Vivi Tele-Meister
    Clemson, SC
    The Vox DelayLab has a dual delay mode that lets you set the ratio of the repeat times as well as the ratio of the mix of the two repeats. So if you wanted the dotted eighth repeats to be louder than the quarter note repeats, you could.
  11. CT SA
    CT SA TDPRI Member
    Cape Town, South Africa
    The Line 6 m9 does can do this. You set up the 2 delays and the tap tempo sync's them both.
  12. Snowwizard
    Snowwizard Tele-Holic
    Napa
    Nova delay can do it too
  13. themandolinguy
    themandolinguy Tele-Meister
    Surrey
    This is what I've got, and it works great.
