This is interesting! Instrument cable is symmetrical and perhaps it can cancel some noise? Obviously when guitar Vol pot is in the middle the pickup is not symmetrical source? I try to think this? Perhaps there already is an answer somewhere in internet?It's weird; hums with the guitar volume in the mid range, but not at 10 or at 0. That guitar doesn't hum at all with other amps.
Hmm, @schmee, interesting hum problem. Do you have a photo of this PT? This installation? I can't quite picture why the ground wire has to do with the PT. Maybe just me -- I'm a visual guy.
Sorry, totally brain dead when I wrote that.Maybe I misunderstood. Does your PT has an electrostatic shield wire? Is that what you're calling ground?
I'm talking about the green AC Ground.
See post #13, total brain fart using the word "ground". Was talking about the Common.Rereading your post it sounds like you're talking about the routing of wires coming from the transformer. Since power transformers don't have an 'AC ground' wire, this is where I'm confused. Sometimes they have a separate electrostatic shield which would connect to ground. There's no ground on the primary side, and secondaries and their center taps may or may not be directly grounded depending on the configuration. You wouldn't call those 'ground wires' regardless.
Edit: I see now that you updated with a post about this.
Yeah, there are so many wires on this thing... sometimes a bargain isn't such a bargain! 17 wires! I dont really think the PT is my hum issue, but need to get into it. The power tube is only about 1/2" max from the speaker magnet. Maybe that's it. Although it wasn't an issue when this chassis was a Princeton clone. I wonder if Cathode bias would be effected more by the magnet..... Next test will be to remove the chassis and play it away from the speaker.@schmee I would normally just bundle up those extra primary wires (and unused secondary wires) and tuck them away instead of clipping them off altogether. There's not any current flowing to produce fields and you don't really need to worry about them picking fields up either.
I guess I'm drifting my own thread!... UPDATE on the Champ hot rod clone:Just thinking about the Champ I just finished that has some hum. I used a tranny I had laying around that was an export model with wires at both ends, so I jury rigged it like this, the primary wires and ground wire twisted come into the chassis through a hole and alongside the PT. Was wondering if that caused some hum.
