I have a Twin Reverb II one channel has gone out. I haven't used the amp in years pulling out the Volume/Channel select switch or the foot switch I lose 90% of volume and what you hear is distorted in a bad way. Everything else works fine, the only thing I've done at this time is to spray DeoxlT on the tube pins a reset them. I'm looking for any suggestions what the problem might be. I've built quite a few Amps but troubleshooting i'm not very knowledgeable don't want spend much money on the Amp looking to sell it.
