Twenty Year Old Dried On Duct Tape...
Discussion in 'Bad Dog Cafe' started by Tele-beeb, Dec 7, 2020.
  1. johnny7
    johnny7 Tele-Meister
    Prince Albert, Saskatchewan
    I would just put some duct tape over it and carry on unless there is a compelling reason why you want the residue off the case. My next solution would be to buy a new case and sell the old one with new duct tape on it. May not be the optimal solution you are looking for however it does eliminate all the chemicals you are using to get the residue off.
    Tele-beeb likes this.
  2. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    This is me removing old duct tape from a guitar case last year:
  3. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    It will not just wipe off, even with a chemical. When I removed the even longer dried up and embedded duct tape glue from that lacquer finish, there was a lot of careful scraping involved, along with the chemicals. I figured that part was a given, but perhaps I should have mentioned it. It should be much quicker work on a molded ABS plastic than it was on a lacquer finish.
    At any rate, it's not worth more than 30 minutes of your time. If it won't come off with that much of your life invested in it, then just leave it, and learn to ignore it. It's just an ABS guitar case.
    Oh, and, obviously, I would think, try dry scraping/chipping first. I figured that was your [failed] first step, but maybe not.
    Tele-beeb and MrCoolGuy like this.
  4. Tele-beeb
    Tele-beeb Friend of Leo's
    The Bluegrass
    Not sticky at all... dry and bonded. I’m usually good at restoring stuff. But I’m baffled?
  5. MrCoolGuy
    MrCoolGuy Tele-Holic Silver Supporter
    Fort Worth, TX
    makita-angle-grinders-ga7021-64_1000.jpg or maybe
  6. Lucius Paisley
    Lucius Paisley Tele-Holic
    Sydney, Australia
    Anything with a citric base will do it. Lemon conditioning wipes, used liberally, will sometimes work. Orange oil is better.
    For example.
  7. Tele-beeb
    The Bluegrass
    I appreciate the time/life reminder... I’m there, I’ll try to efficiently split my time with more productive endeavors. Great point.
  8. thesamhill
    thesamhill Tele-Holic Silver Supporter
    Harrisburg, PA area
    dougstrum and Tele-beeb like this.
  9. TeleTucson
    TeleTucson Tele-Afflicted
    Tucson, AZ
    Goo Gone is not the same as Goof Off. Try the latter. It does have a powerful solvent smell but the smell goes away when dry.
  10. HotRodSteve
    HotRodSteve Poster Extraordinaire
    The Shmudson Valley
    Doesn't work with fuel lines. Ask me how I know this.
  11. Tele-beeb
    The Bluegrass
    Actually, I have deemed that “my last resort.”
    MrCoolGuy and thesamhill like this.
  12. Tele-beeb
    The Bluegrass
    How do you know HotRodSteve? Was it a Miata?
  13. HotRodSteve
    The Shmudson Valley
    No. It was a friend's Nissan that sprung a fuel leak. He called me dead on the road, I came to the rescue, we wrapped up the leaking fuel line with duck tape, all we had, it lasted about ten minutes, started spraying fuel all over the engine, lucky it didn't ignite but it got him to his mechanic. Apparently gasoline eats thru the glue in duck tape. Who knew?
  14. thesamhill
    Harrisburg, PA area
    I'm no chemist or anything, but I've never had great luck removing sticky stuff with sticky-stuff remover after the sticky stuff isn't sticky anymore.
    But the main thing that bugs me about removing tape is the stickiness so if it's solid, maybe just count that as a blessing, hit it with a grinding stone Dremel bit if there are any pokey or sharpish parts, and get a new sticker for that spot or hit it with a sharpie.
  15. Old Deaf Roadie
    Old Deaf Roadie Friend of Leo's Silver Supporter
    Oregon
    Ammonia works on tape adhesive if you can stand it.
  16. Tele-beeb
    The Bluegrass
    I may try that... :)
    thesamhill likes this.
  17. Diytelecaster
    Diytelecaster Tele-Meister
    After spending 12 years making gaffa tape, I'd recommend wd40
  18. tweedman2001
    tweedman2001 Tele-Afflicted
    Was North of There, Now Way Way South of There
    What's the problem with duct tape? :D
  19. dougstrum
    dougstrum Friend of Leo's
    blu ridge mtn cabin
    Where's Red Green~
  20. uriah1
    Around
    De-natured alcohol works on sap.
