Tweed Princeton 5F2-A Overdive
Discussion in 'Amp Central Station' started by Rekosz, Oct 15, 2020.
  1. Rekosz
    Rekosz TDPRI Member
    Poland
    Hey,
    I got myself great Tweed Princeton clone with 10" G10C/S - 75 inside a while ago, great amp, sweet cleans, super responsive to the touch BUT I cannot get it to overdive naturally, ever. I play telecaster with classic vintage output Callahan Pickups. Even when I dial it to the max and hit strings hard its still super clean and SOOOO LOUD. Why is that? Is it because this amp architecture doesnt allow it to overdrive and naturally its super clean amp (I dont think so, I never played vintage one but saw a few videos and they were able to overdrive it quite nicely)? Or maybe speaker is too efficent? I was wondering if putting Jensen P10R-F inside would help with that?
  2. Kevin Wolfe
    Kevin Wolfe Tele-Holic
    Lakeland FL
    Try a less efficient speaker.
  3. KC
    KC Friend of Leo's
    Missoula, Montana
    yeah, or just get a decent pedal. A Klon type is designed to push an amp like that into overdrive but there are lots of other flavors, depending on your taste in mid-humps & compression.
  4. uriah1
    Around
    What is in their v1 preamp...anything lower than a 12ax7?
  5. Rekosz
    Rekosz TDPRI Member
    Poland
    nope, standard tung sol 12ax7
    uriah1 likes this.
  6. corliss1
    Lansing, MI
    Might be time to check some amp voltages, if you're comfortable with that.
  7. Rekosz
    Rekosz TDPRI Member
    Poland
    hmm I know nothing about that stuff so I'll pass :D but could you say a little bit more about that? how would that affect sound?
  8. sotob
    sotob Tele-Holic
    Up the street a bit
    I was in similar situation position last wkend. I got a reissue Fender '57 Custom Deluxe. The previous owner put in a master volume on it, so I thought I could crank it up at night. No luck. Tried a few things, but none helped. I know the quick fix is to put a pedal in front of it, but I wanted no pedals involved, so back it went.
    Good luck!
  9. dankilling
    dankilling Tele-Afflicted Silver Supporter
    Lehigh Valley, PA
    Post a gut shot. A 5f2a should start to break up around 5-6 on the knob.
    Watto likes this.
  10. corliss1
    Lansing, MI
    @Rekosz - also, welcome to the forum :D
    Since the amp is a clone, there could be any number of modifications made. Taking voltage readings and comparing the parts to the original layout/schematic would be the only way to know for sure what is happening with that amp, especially if it is not working as intended.
    Posting some photos may help as well, but you should only open the amp if you're aware of the dangers of high voltage.
    Watto likes this.
  11. dan40
    dan40 Friend of Leo's
    Richmond Va
    A gut shot would tell us quickly whether or not the circuit is built to original specs. It could be something as simple as a missing bypass cap on v1 that is causing the lower gain.
    Watto likes this.
  12. High Head Brad
    High Head Brad Tele-Meister
    That doesnt sound right. I have an original and it breaks up easily..... about 4-5 on the amp's volume
  13. Cali Dude
    Cali Dude Tele-Afflicted
    California
    I used to have an old tweed Princeton. It did get crunchy pretty quickly. It must have a different circuit.
  14. caspersvapors
    caspersvapors Tele-Meister
    CA
    my thought as well
  15. ThermionicScott
    CID
    Just trade with someone who wishes their 5F2A clone was louder and cleaner! ;)
    dan40 and corliss1 like this.
  16. Rekosz
    Rekosz TDPRI Member
    Poland
    here are the photos
  17. corliss1
    Lansing, MI
    Well, so much for that bypass cap theory.................as that is in place
    dan40 likes this.
  18. Rekosz
    Rekosz TDPRI Member
    Poland
    so it looks allright? Maybe its that speaker? its super efficent compared to Jensen P10R, could it be it?
  19. jmp81sc
    jmp81sc Tele-Meister
    Orange County
    I would check all of the resister values to make sure they are correct. You can use the color codes printed on the resistors, then compare them to the layout values. Kingfan has a thread over at the Shockbrothers section on 5F2A layout. This will be a little different then the Fender layout but the resister values should correspond.
  20. dankilling
    Lehigh Valley, PA
    Have you tried a different 12ax7 in there? Might just be a weak tube. Other than that, like others have said verify the resistor values. I'd start with the V1 plate resistors, those have a big impact on how the preamp will behave. If you want earlier grit, maybe replace those with 120k or 150k values? That will change the way the amp behaves with preamp distortion vs power amp distortion, but it will cause earlier breakup. Also, be sure the NFB resistor is correct as well- that changes early breakup and noise floor. You could swap that for a 47k to give less NFB and force it to break up earlier as well. I have a 6aq5 based 5f2a I'm using 120k's in to keep the amp 'bedroom level' friendly.
