Tweed Deluxe Build
Discussion in 'Amp Central Station' started by Munga, Nov 22, 2006.
  1. getbent
    getbent Telefied Silver Supporter
    San Benito County, California
    Good job narrowing it down... you're close.. hang in there.
  2. nonvintage
    nonvintage Tele-Holic
    San Diego
    I am in awe of the care and concern of all you tech oriented fellow TDPRI bros. I salute you all and wish you all the best. Munga, Good Luck on ya.
  3. ajmikula
    ajmikula TDPRI Member
    Vancouver
    Hey - this is easily the most friendly and helpful board on the net - or if not, then it's definitely in the top two. I don't have a lot of posts because any time someone has a problem, five people have offered suggestions on how to fix it before I can read it! :p
  4. Munga
    Munga TDPRI Member
    Santa Barbara
    I finished the amp!!!!!!
  5. nonvintage
    San Diego
    Congratulations! How does it sound?
  6. Munga
    Munga TDPRI Member
    Santa Barbara
    Sounds excellent. Nearly perfect. I can't wait to get some clips up, probably in a day or two.
  7. JohnnyCrash
    JohnnyCrash Doctor of Teleocity
    Fullerton, CA
    Sweet!
    What was it?
  8. ramseybella
    ramseybella Tele-Afflicted
    Santa Fe New Mexico
    I was thinking of building one!!
    But now I don't know sounds Like I should down a bottle of Crown before I start??
    Just kidding guys just don't have the space to build one.
  9. Munga
    Munga TDPRI Member
    Santa Barbara
    The 1M resistor was crossing with ground on the jacks.
    Here is a diagram:
    Such a small mistake. :(
  10. Munga
    Munga TDPRI Member
    Santa Barbara
    After much delaying, I finally recorded some tones with this bad boy.
    http://www.soundclick.com/bands/songInfo.cfm?bandID=387355&songID=5299116
    Pretty much everything in that song was recorded using the Tweed Deluxe with a '52RI Tele. SM57 into Protools.
    http://www.soundclick.com/bands/songInfo.cfm?bandID=387355&songID=5284566
    Theres a straight clip of the deluxe using a tube mic from a distance. Sorry for the bad playing, it was one take and I sort of made of what I was playing as I went. Plugged into bright channel. Bright volume is dimed. Normal volume is at about 12:00, tone dimed. It starts out on tele neck, 1/2 volume on guitar. Then, tele bridge, 1/2 volume. After that neck at full volume and then bridge at full volume.
  11. sjhusting
    sjhusting Tele-Afflicted
    Germany
    Sounds like a Tele into a 5E3. A perfect combination. Congrats. When I plugged into mine for the first time, my eyes did this :eek: then my mouth did this :D and now whenever I play any other combination I look like this :mad:
    steven
  12. Munga
    Munga TDPRI Member
    Santa Barbara
    Righteous! I considered this amp and guitar combo to be a one trick pony at first. However, it is all I use now. I can go from perfect cleans to down and dirty dirt with my guitar knob. Here is a quick review of the Weber kit if anyone is interested:
    Everything was supplied correctly, nothing left out. Plenty of wire to work with. However, a couple of problems. Bad PT, as I said earlier, however, a new one was promptly sent to me as soon as I contacted Weber. Also, the 12AX7s he supplied were absolute ****. They made the amps squeal and shriek. I spent a long time trying to find wire errors, until I popped in 2 12ax7s from my Hot Rod Deluxe and the amp shined away. So, if you are going to get a Weber, factor into your price range getting some JJs or comparable, and have them ready. It always sucks when the amp works but the tubes don't and you have to wait for them to arrive.
