NoTeleBob
I looked at that one as well, I figure I will build the new cabinet just large enough to accommodate a 10". My thoughts exactly about the brightness of these amps. I think the right speaker will do the trick. These look like a real steal for someone who wants a little more power.
Its pretty funny to read all the comments about the Bronco(Frontman). People gush over them. Any suggestion that it might be a Frontman is ignored or disregarded as impossible. I could see myself fall into this as well. I have been comparing the audio clips of the Bronco, to clips of vintage tube amps and it sounds like it fits right into the mix. I believe it is a lot like wine. So many people believe that they can tell the difference between high end wines and the cheap stuff. In several extensive tests, with well known people in the food industry, this has been proven false. There was no consensus when comparing them. Price has nothing to do with it. Quality on the other hand is a different story. Well made wine will always be expensive because of all the effort. It isn't always good though. With music, a good musician can always pull the best out of even the cheapest gear. I realize the feel of a Frontman will never be the same as a tube amp. I am sure there will be a lot of knob fiddling. That is one thing I love about the Champ. It has one setting, good.
The other plus to the Frontman 25 is that it's a spring reverb. Small, but spring, and you can easily upgrade to a larger tank for $25.
