Tuning stability in motion live
Discussion in 'B-Bender Forum' started by eddiewagner, Apr 10, 2020.
  1. eddiewagner
    eddiewagner Poster Extraordinaire
    ROCK!linghausen/germany
    Hi friends, I took my new tele with the fenderbender to a rehearsal. It’s kinda hard to keep the pullstring still when moving around. I got 11-52 strings on it. Any suggestions? Or will I get used to keeping the guitar really still? Happy Easter everybody and stay healthy
  2. Peegoo
    Peegoo Friend of Leo's
    If your pull-string has adjustable spring tension (the return spring or springs), give it a few turns to increase the spring pull. That prevents the weight of the guitar from activating the movable strap knob. If you don't have adjustable tension, you need a stronger spring.
    As you get used to it, you may be able to relax the spring to make bending a bit easier.
  3. eddiewagner
    Nope, there is nothing to adjust on that spring inside. Hmmmm....
  4. eddiewagner
    Maybe a thicker b-string?
  5. asatfan
    asatfan Friend of Leo's
    Beautiful Brown County, IN
    I'm thinking you may have to remove the spring and snip off a coil or two and put it back on. I would try a little at a time. Possibly a stout zip tie around a few coils?
    I have Evans Pull Strings in my Asats and they have completely adjustable tension, which is great because I set it very stiff as I found I tend to pull down on the neck while I'm playing.
  6. Pineears
    Pineears Tele-Afflicted
    I don’t have adjustable tension, but I have learned not to pull it down unintentionally, most of the time. Swapping stings is easy to try. Easiest to try if you don’t have a big string selection is swap the G and B strings. Which gives easy G string bends to accompany the B Bender.
    eddiewagner likes this.
  7. Silverface
    Lawndale CA
    ALL Pull String b-benders have adjustable tension!
    You have a different bender. Who installed it? Please post a picture of the mechanism, as there is usually a way to adjust the tension
    But is that what you mean by "moving around", i.e. unintended bends? Or is the strap sliding on your shoulder?
  8. eddiewagner
    I got no idea where to find a stronger spring here in Germany
  9. eddiewagner
    Good idea with zipties
  10. eddiewagner
    Nope. This ain’t got nothing. Just a wheel to adjust the tuning
  11. eddiewagner
    That is a good idea!
  12. eddiewagner
    Tadaaahhhh! Problem solved: guitar on strap much higher, that inside shaft screwed in all the way, and swapped b for g string on a 9-42 set. thanks guys. The swarm knowledge in this place is amazing. Happy Easter everybody. Stay healthy please.
    That Cal Webway likes this.
  13. Peegoo
    Outstanding!
  14. Silverface
    Lawndale CA
    Then it's not a Pull String. The Pull String is a high end, fully adjustable (both throw length and tension) stainless steel and Delrin B-bender made by Dave Evans.
    If it has a wheel my guess is it also has a steel plate on the back (with no access to the mechanism without removal of the entire unit) and is the lower-end "Fender Nashville B-Bender" equipped with a "Parsons-Green" bender - now made by Hipshot.
    Gene used the "Pull String" name for a short time in the 1970's but since then his primary b-bender has been called the "Parsons White".
  15. eddiewagner
    Sorry for being such a Greenhorn and causing confusion. My fault. ROCK on my friend.
  16. ChrisLarcombe
    ChrisLarcombe TDPRI Member
    Midlands, UK
    glad this got sorted for you dude!
