Tuning Peg Question
Discussion in 'Tele-Technical' started by Mike Tele, Sep 16, 2021.
  1. Mike Tele
    Mike Tele TDPRI Member
    England
    Hi, i own a left handed tele shape guitar. However, when tuning it i have to turn the pegs towards me to sharpen and away from me to flatten.
    This is the opposite of what every other guitar seems to do. It tunes up fine though, and plays really well.
    Here are some photos of the headstock to see if you can see something out of place.
    nojazzhere likes this.
  2. ChristoMephisto
    ChristoMephisto TDPRI Member
    Ottawa, Canada
    That's normal for a lefty or even a reverse headstock neck. The gears works both ways.
    What was the question ?
  3. nojazzhere
    nojazzhere Doctor of Teleocity Ad Free Member
    Foat Wuth, Texas
    It might be better to describe turning them "clockwise" or "counter-clockwise"..........
  4. Mike Tele
    England
    I always find it easier to say turn towards or away but from my view when i'm playing, i turn counter clockwise to sharpen and clockwise to flatten which is the opposite of every other left handed guitar i've ever seen.
    It's such a strange thing, everything on the surface seems to be correct and it tunes fine and holds its tuning which is great.
    If you imagine yourself as a left handed player, then turning the pegs towards you (Counter-clockwise) should flatten the strings....but it sharpens instead!
  5. Mike Tele
    England
  6. WingedWords
    WingedWords Friend of Leo's
    UK Europe.
    I've got a 62 reissue Jazz Bass with tuners that work the opposite way to what's usual. It was normal for the period and I can't say I've ever really noticed a problem.
    Fretting out and Mike Tele like this.
  7. KATT
    KATT Tele-Holic Platinum Supporter
    Essex, England
    If you have an object in front of you facing away from you and want it to face you, you can turn it clockwise 180 degrees, or anticlockwise 180 degrees to make such object face you. So whichever way you turn it, you are turning it towards you. I think that's what makes using clockwise and anti clockwise a bit less confusing!
    Anyhow, I suspect that judging by the brand and the quality of the finish around the truss rod hole, that the manufacturer just used the cheapest tuners they could buy, which happened to have the reverse gear of what you would usually find on a left handed guitar.
    I have a reissue Jazz and Precision and both have tuners that work the opposite way to normal. It's quite quick to get used to it I found.
    Mike Tele and nojazzhere like this.
  8. nojazzhere
    Foat Wuth, Texas
    I understand you now. Per your pictures, those tuners don't look like "right-hand" units simply put on a "left-hand" neck.....I suspect they are inexpensive Asian imports that just weren't made correctly. If it bothers you, (and it would bother me) I'd replace them with proper "left-hand" ones. Otherwise, just live with them. ;)
    Mike Tele likes this.
  9. Sea Devil
    Sea Devil Friend of Leo's
    Brooklyn, NY
    Get a guitar with three-on-a-side tuners and see how you like that!
    Fretting out likes this.
  10. Mike Tele
    England
    Good to know. Thanks.
  11. Mike Tele
    England
    Ah, makes sense. Do you think it will cause any problems down the line when i have to restring it?
    If not, then i have no problem carrying on with it because that aside, it plays nicely.
  12. Mike Tele
    England
    It did bother me but i figure as long as it's not hurting the guitar in any way then i've got no problem turning them the wrong way. Appreciate your reply. :)
  13. Mike Tele
    England
    I've blown my budget on this cheap guitar for now haha. We'll see where the land lies in a years time.
  14. ChristoMephisto
    Ottawa, Canada
    Ok now see it, it's revered geared due to the position of the tuners.
    I have a couple basses from the early 70s with that, messes me up too
  15. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    It would look kinda funky, but you could wind the strings in the opposite direction.
  16. Sea Devil
    Brooklyn, NY
    My point in the post above is that once you've had a guitar with a 3X3 headstock, you don't even think about which direction to turn the tuners when they're on that side. You'll get used to it in no time.
    ChuckC likes this.
  17. ChuckC
    ChuckC Tele-Meister
    Maryland
    I had been playing guitar for about 60 years before I realized that it ain't "righty tighty, lefty lucy". I bought a battery powered string winder. The first time I used it, replacing the strings on my acoustic.... I was wondering why the old strings were popping while I thought I was loosening them.......I always followed my ear and never noticed that making the note higher, strings tighter, was turning counter clockwise
  18. moosie
    Western Connecticut
    And how many more years before you realized Lucy had nothing to do with it.
    "Loosey" is the term, I believe. Lucy is the opposite of Ricky.
    ChuckC and Peegoo like this.
  19. Peegoo
    Peegoo Doctor of Teleocity
    Challenging Definitions of Sin
    You do have the strings going the proper way around the tuner posts, correct?
    Post a pic of the front of the headstock.
    ChuckC likes this.
