Tuning machines for American Special -- recommendations?
Discussion in 'Telecaster Discussion Forum' started by KC, Sep 21, 2019.
  1. KC
    KC Friend of Leo's
    Missoula, Montana
    Been playing the Special for a while now and my only complaint is tuning stability, especially compared to my American Standard. Been playing a lot of demanding gigs lately, outdoor stuff with a lot of temperature fluctuation, and the Special tends to drift after a few songs. Will new tuning machines solve this? Which ones? Thoughts are welcome. Good-looking good-sounding good-playing guitar otherwise.
    Fretting out likes this.
  2. Raimonds
    Raimonds Tele-Meister
    Latvia
    No.
    Fretting out and bgmacaw like this.
  3. LowCaster
    LowCaster Tele-Holic
    Paris, France
    What makes you think the tuning machines are faulty? Usually tuning machines are failing one by one. If the tuning is shifting on all the strings at the same time, it could be the neck (or body) moving for some reason...
    bgmacaw and Fretting out like this.
  4. oatsoda
    oatsoda Tele-Holic
    The Shack
    Think you may be barking up the wrong string tree.
  5. Slim Chance
    Slim Chance Tele-Holic
    Beltway, USA
    You had me at temperature fluctuations. The heat is causing the guitar to expand and contract and the tuning will change. Perhaps this particular guitar is more susceptible to the heat due to the particular wood used in the neck and body.
  6. Fretting out
    Fretting out Tele-Holic
    Land of Mary
    Problem could also be the strings are getting bound up in the nut 90% of the time when people change tuners they should really be dealing with their nut
    Or if the temperature change is drastic enough I don’t think tuners or nut work will fix it and you have to adjust tuning as the temperature changes
    And if you put a fresh set of strings on for every gig , giving them a proper stretching is a must
    bgmacaw likes this.
  7. Buzzgrowl
    Buzzgrowl Tele-Meister
    Switzerland
    +1
    It's iether bad strings or a sticky nut. Change your strings and clean and lube your nut.
    If it really is temp related, there is no fix.
  8. bgmacaw
    bgmacaw Friend of Leo's
    Near Athens GA USA
    If you string your guitar like this then maybe, just maybe, locking tuners will help. Otherwise, the problem is most likely in the nut, string tree or saddles as long as the neck is stable.
