Tuner post wraps how many ?
Discussion in 'Vintage Tele Discussion Forum (pre-1974)' started by Fretting out, Jul 16, 2019.
How many wraps on you tuner post
Poll closed Jul 30, 2019.
  1. As many as possible
    7.1%
  2. About 3 times around
    67.3%
  3. Just 1
    8.2%
  4. Other
    17.3%
  1. Fretting out
    Fretting out Tele-Holic
    Land of Mary
    How many wraps do you put on your vintage kluson style tuner posts ?
    And why?
    I usually just use the rule of going 2 and a 1/2 to 3 posts past the post I want to use then clip and wind except for the high E and B I use the whole string on them .
    I don’t have a specific tonal reason for this I just find it works for me. I usually have very little slippage doing it this way.
    I’m just curious what you guys think and how you do yours?
    I was watching a video with Danny Gatton and he said he liked to put as much string around the post as possible.
  2. Sparky2
    Sparky2 Friend of Leo's
    Harvest, Alabama
    It all depends upon the gauge of the string.
    My heavy E and A strings get one turn around the post before I begin turning and tuning-up.
    D and G get two turns.
    B and bottom E get three or more.
    *boom*
    That's how you do it right there.
    The Angle, LeicaBoss, hdvades and 5 others like this.
  3. Steve 78
    Steve 78 Friend of Leo's
    Melbourne, Austraila
    I've read 1.5 minimum, to avoid slipping I guess? I aim for about 2-3 but I'm pretty bad at estimating.
  4. VintageSG
    Yorkshire
    The equivalent of two posts for E&A, two and a half for D&G then I'd guess roughly three posts worth for b&e.
  5. EsquireBoy
    EsquireBoy Tele-Meister
    Paris, France
    For the longest time I was a believer that the more turns the better. But actually too many turns lead to tuning problems since the string has more chances to get loose around the post. I now aim at 3 wraps max and 2 wraps for low E and A.
  6. Ron Garson
    Ron Garson Friend of Leo's Silver Supporter
    How I like to do mine.
  7. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    I do pretty much the same thing. Using the whole string on the E & B gets the strings to the bottom of the post changing their angle going to the string tree or nut.
    Fretting out likes this.
  8. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    I started out with the 'go two posts past the post and wind it up' but after seeing the re-string video of a famous band roadie on youtube a few years back I changed my method to what he does and I've liked it a lot better -- plus it's faster.
    Bring the string to the post, wrap around (3 on low strings 4 on high unwound strings), then feed tight through the post eye (or cut and stuff on split shafts), tighten to pitch. No measuring and no slipping strings.
  9. ricknbaker
    ricknbaker Tele-Afflicted
    Watford, UK
    I always put them on like this.
    Which gives me about 2 turns round the post. All my tuning issues went away once I started doing it like this
  10. Chunkocaster
    In space with Ziggy
    I end up with 2 to 4 wound to thin strings on split shaft tuners.
    I use 3 fingers with a bit of string slack to measure string length before cutting and stuffing it in the hole. I add a little length as I go using a Jedi mind technique to acquire the force that guides me.
  11. Bob Arbogast
    Bob Arbogast Tele-Afflicted
    Lowell, Michigan USA
    With the safe-t-post tuners, I measure and cut the string at the following lengths beyond the post:
    • low E: 2-1/4
    • A: 2-1/2
    • D: 2-3/4
    • G: 3
    • B: 4
    • high E: 4
    I don't know how many total wraps for each string. But using these string lengths seems to provide the proper down angle, which is different for each string.
    On the B and high E, I first make a half-wrap counter clockwise then through the slot, before beginning the clockwise wrapping.
  12. Sanity Inn
    Sanity Inn Tele-Meister
    Ottawa, Canada
    Wallaby, Fretting out and ricknbaker like this.
  13. RottenTheCat
    RottenTheCat Tele-Meister
    Drambuie, Africa
    No more than two on any string....maybe 2-1/2 on unwound. Many wraps = stretch, tuning, bending, whammy issues.... Just what locking tuners seek to avoid.
  14. FenderGuy53
    FenderGuy53 Poster Extraordinaire
    Marion, NC
    The whole point in guitar stringing is to maximize the break angle of the string from the post to the nut.
    Personally speaking, I prefer a single layer of string against the post. No need to make your string post look like a fishing reel. :eek:
    fordguy_85, VWAmTele and Fretting out like this.
  15. hemingway
    London, UK
    More than one, less than too many
  16. FenderGuy53
    Marion, NC
    John Nicholas, jonnyfez and VWAmTele like this.
  17. Guitarteach
    Jam it through, one and half to two wraps with the pinch method highlighted above trapping the excess.
    No problems with tuning in years.
  18. Adam Wolfaardt
    Adam Wolfaardt Tele-Meister
    France
    I do 2 or less on the E and A. About 4 on the D and G. Since the machine heads for those strings are far away from the nut and there is no string tree its a good idea to use the extra turns to push the strings down some. Hight two I do about 4. Since there's a string tree I'm not too fussy
  19. schmee
    schmee Poster Extraordinaire
    "Other" Yep. A couple on the low E string, maybe 6-8 or so on the high E string.
  20. schmee
    I disagree. Sail a sailboat some time and try one wrap on the winch when the wind blows. :>)
    Once the strings settle from new, my electric guitars rarely even need tuning. I'll pull my #1 strat out of the case a week later and it's in perfect tune. No tying the ends or other hocus pocus, just wrapped on the post. The wraps spiral up against each other, compressing the stack of coils against each other and against the string through the hole or slot.... holding the string tight.
