Tune-o-matic bridge
Discussion in 'Telecaster Discussion Forum' started by Supermaverick, Jul 27, 2011.
  1. Supermaverick
    Supermaverick Tele-Meister
    Katy, TX
    So fellas... How much needs to be routed out for a tune-o-matic bridge so it'll be the proper height to the fret board. I'd really like to mount a b7 bigsby to my new thineline tele I'm in the process of making... I've done some research and I've heard "about a quarter inch". But you and I both know, "about" anything just doesn't cut it...
  2. RedDirt
    RedDirt Tele-Meister
    Decatur, Texas
    Are you talking about routing the body to lower the TOM?
  3. Wayne Alexander
    Wayne Alexander Friend of Leo's Silver Supporter
    Los Angeles, CA, USA
    You could instead just shim the heel end of the neck pocket to give the neck a little more angle, that would make it unnecessary to rout a trough into the guitar body.
  4. Supermaverick
    Katy, TX
    Yes sir. That's what I'd figure you'd have to do to mount it...
  5. RedDirt
    Decatur, Texas
    Don't see any reason why you would have to do that.
    I can't find a TOM in this mess right now, but it is not much taller than a vintage bridge (or a mustang roller bridge) both of which work with a Bigsby.
    There has been a lot of discussion on here lately about shimming necks, etc. for a Bigsby, but I truly believe that most of this is based on people having problems, finding a bad solution for them and then assuming that their solution is the right and normal way to set up a tele with a Bigsby.
    Same thing with bridge height and action height. Figure out what the real issue is and fix it before you go around shimming necks or sticking dimes under your bridge saddles.
  6. Supermaverick
    Katy, TX
    Well the heck with it then. I'll just mount it then see whats gotta be done. I guess even if I had to route it out or shim the neck I'll be able to see how much exactly it'd be. It wouldn't change where the holes need to be... I agree though. Sure don't want to route or shim anything if it's not absolutely required...
  7. PaddyWagon
    PaddyWagon Tele-Meister
    Huntington Beach, CA
    When I put a TOM on another guitar style, the neck needed a 3% tilt backwards (ie. towards your body). The TOM was just a little bit higher so the little tilt raised up the butt end to match and the truss didn't need adjusting. Your mileage may vary. Measure twice etc...
  8. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Peterborough, UK
    You will almost certainly need to shim the neck if you put a TOM on a Tele.
    Routing can work (take a look at some G&L Tele-style guitars that do that I think) but for me a small shim works just fine.
  9. Robbied_216
    Robbied_216 Tele-Afflicted
    Sydney to L.A.
    With all the discussion of a "tight fitting neck pocket", is there not a concern of (kind of) de-coupling the neck from the body when you start shimming it?
  10. Dan German
    Dan German Doctor of Teleocity
    Left of the Left Coast
    You'd sure think so, but I've played some sweet-sounding guitars that had shims under the neck. And some duds with a tight neck pocket.
  11. kiefe-caster
    kiefe-caster Tele-Holic
    Derry, Northern Ireland
    What would qualify as an appropriate shim for a tele neck pocket that has a TOM bridge setup ?
